Question about Crosley CR245 Turntable
Crosley #cr245, no sound on any function,i can select function but will not come on,front panel lites up. turntable will not turn.
3 Suggested Answers
SOURCE: Turntable does not turn
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Posted on Aug 07, 2009
  • 5 Answers
SOURCE: i recently aquired a crosley cr245 cd recorder
YOU CAN TRY AT EBAY INDIA GLOBAL DIRECT BY
Posted on Aug 31, 2011
HOW I CAN TO GET IT COME BACK ON AND PLAY MY VINYLS AND MY CD'S AND RADIO?
It sounds like you have lost power to it. So the obvious thing to do is check the fuse in the plug and if that is good to look inside for the fuse there. If you can't solve the problem yourself, then you need to take it to a service centre. Don't go inside it if it is still under warranty.
Apr 17, 2015 | Crosley CR245 Turntable
How do I get into it to fix the belt
U remove the platter from up above and then expose the innards. there usually is some sort of clamp around the bottomof the record spindle that holds platter in place.
Mar 06, 2015 | Crosley CR245 Turntable
I put my turn table on phono and did everything the instruction manual said but the thing just won't spin
Check to see if the belt in on and has not come off under the round platter the records sits on.
Apr 12, 2014 | Crosley CR245 Turntable
Trying to play an lp on CR245 Crosley machine - no manual - can't make the turntable turn. I have never used this before. Thank you. Mary
This is very sensitive, i will suggest you check manualsonline.com for the manual, this will be a good guide.
Nov 26, 2010 | Crosley CR248 Turntable
Have Crosley CR245 the CD drawer does not open. H...
it sounds like the unit has a broken open door belt take the lid of and look for a black broken belt you can replace it with a rubber band of the same size
May 13, 2010 | Audio Players & Recorders
Lost manual for CR248
try typing cr248 manual on internet
Jan 29, 2009 | Crosley CR248 Turntable
Crosley CR245 Turntable Logo
63 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
