Question about Whirlpool Duet GHW9150P Front Load Washer
Comes up with code F 2 - Whirlpool Duet GHW9150P Front Load Washer
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
your f2 error means Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Testimonial: "Thank you very much. Will see how much pump cost or buy new machine."
How do I find out which is the 6th plug, wire or coil pack that's not firing that what it says when my light comes on and I have it checked
Pull codes if it says coil 2 not working swap it with the one right next to it and run the car. Pull codes again. If it comes up at the other coil say 2 it's the coil.
Jun 01, 2014 | Cars & Trucks
Code p0302 did plugs and wires still comes back
Move the coil to plug 3 and plug 3 coil to plug 2. That will prove faulty coil pack.
Nov 18, 2017 | 2002 Hyundai Elantra GLS
Mitsubishi WS-55859 power light comes on and then goes off.
I get an error code of 2- 2 x 10 etc Ten times I saw two blinks of the on light. I had a power relay replaced in the year one ,fixed it.then. what do I do now to fix it. What part would you replace thanks.
Dec 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
What is 2wire error code 2
When you got this error were you running the installation wizard disc for AT&T?
Because as far as my knowledge with AT&T (Bellsouth) this error code comes out when installing the modem using the Installation Wizard CD, this comes out on a version 3 cd. The error code means
"Failed to Upload to ISP" this possibly could mean that you are not connected to the internet.
Sep 22, 2009 | 2wire 2700HG-B Router (2700HGB)
SONY RDR-GX3 region code unlocking
prepare: your one for all
1. select dvd device on remote
2. hold magic button until flashes twice/comes out
3. enter device code 0533 (this programe the GX300 as the DVD choice in your one for all)
Now program buttons 1..5 with the following codes using the instructions below:
1 - 189
2 - 255
3 - 095
4 - 221
5 - 079
1. hold magic button until rabbit comes out
2. press 994
3. press magic
4. enter 3 digit code from above
5. press button (1..5) where to program it
6. repeat steps 1 to 5 for all keys.
have it a go:
1. remove disk, put player on standby
2. press 1,2,3,4,5 - success is displayed and plyer starts up
3. press 1,2,3,4,5 - player shuts down and BINGO!
Good Luck!!!
Mar 22, 2009 | Sony RDR-GX3 DVD Recorder
Help!
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
May 03, 2008 | RCA RCR412C Remote Control
2-2 code
convergance ic are bad:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 02, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Whirlpool Duet GHW9150P Front Load Washer Logo
273 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
