Question about Compaq Computers & Internet
Having terrible problems cannot open files .printer not working as well .freezing when trying to access.and i need our original c.d. for computer had less than a year and cannot find disc. need a new one. writing on all stuff is really small no matter what. computer is presario pc sr5013wm prod#:rx894aaba s/ncnx717078x .help!
    Novelist:
    Scholar:
  • 96 Answers
OK, it sounds bad, but you could try the windows system restore process: start programs, accessories, systems tools, system restore. Give that a shot. If that doesn't work, try to create a recovery CD using the program that is preinstalled on your system. Here is a link to the directions on how to do that, and also how to order CD's from the manufacturer.
Note: If you use the phone number and it's still under warranty, HP/Compaq should be able to send them free. If not, it usually costs only $10-$15.
The link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07143&lc=en&cc=us&dlc=en&product=3380263&lang=en
Posted on Jul 09, 2008
After cropping and saving a picture, how do I revert it back to the original photo?
Hello Karen,
You need to go to the original picture file. As you can only undo cropping or other changes while the undo option in edit menu is active, usually early on when file is open in programme editing with. Just after doing the cropping.
So hopefully you didn't crop picture then write over its original file. You saved it { save as } to a new file. If you did overwrite original file after cropping; then you will need to relocate this original picture from the source it came from to access original composition, size etc. If from your camera then simply re transfer to your computer & open it there.
If you're not sure about where it is on your computer then you can do an open search by typing in part of the file name or file format { part after the dot in filename & go through the results lists to try & locate it.
Hope this helps.
Dec 18, 2012 | Microsoft Digital Image Pro 10
My computer accesses the file on the external hard drive, starts to download the information, then my computer freezes. The only way to get out is to power down, holding the computer button down till it...
maybe the file is corrupt or has a virus. Do full virus scan on freshly rebooted computer. try starting the PC in safe mode (F8 when booting) and open the file. do other files of the same type open up ok?
Sep 27, 2017 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
I have problem opening the photos from a friend in picassa
Hello
This problem can be resolved by opening the "Control panel" and selecting "All Profiles" under the "Color Management" file. Add the "sRGBIEC61966-2.1" profile to the "ICC Profiles."
Make sure that the digital photo file that you're trying to access isn't open or in use by another program on your computer. Oftentimes, two programs can't access the data contained within a file at the same time. If your photo is already open in another program, for example, you wouldn't be able to open it in your digital photo viewer/file manager.
Make sure that the file format of the digital file you're trying to open will actually work with the file manager you're trying to use. Not all programs are going to be able to open every file type. There are dozens of different photo files types in existence. Look at the photo file's extension and then look in the instruction manual that came with your file manager to determine if that program can read that particular type of file.
Reinstall your digital photo viewer file manager utility. If you purchased your program in a store, insert the CD-ROM you used to originally install it into your computer and select "Repair" when its setup program automatically opens. If you installed your digital photo viewer file manager utility from a computer file you obtained on the Internet, execute the original installation file and select "Repair" to reinstall your program on your computer.
Make sure you have the latest version of your digital photo viewer file manager. Programs are often updated by their original manufacturers to fix errors and issues that users have been known to have. Open your program and click on the "Help" tab. Look for an option that reads something like "Update" or "Check for Updates" and select it to connect to the Internet and make sure that you have the latest version of the program installed on your machine.
Nov 05, 2010 | Computers & Internet
Computer freezes when I try to close an open program.
The system files may be corrupted.Insert the disk of the OS and try for a repair.
Jan 01, 2010 | Toshiba Satellite A105 Notebook
When I try to access a file on my WD MYBOOK it freezes my comp
I/O problems generally indicate hardware problems in your computer, the USB circuitry of the drive enclosure or the circuitry of the drive insode the enclosure.
First try the drive on a different computer, if it works the problem is in your PC, if it fails, take the drive to your local PC shop and ask the techs to move you hard drive into a new enclosure and test it, if it works the problem is in your enclosure, buy the one they tested it in and you're good to go again. If neither works the issue is in the actual hard drive and you will need the help of a pro to get your data back, if this is the case reply with your location(Country, State and City) and I will refer you to an appropriate facility to help you get your files back.
Hope this helps FixYa,
Chris
Sep 24, 2009 | Western Digital My Book Essential Edition...
MS Access 2007 freezes when opening a basic TABLE. Please assist in resolving this frustrating problem.
You might try the "Compact and Repair" database option first before working on the database. Click on the "Office Button", then click on "Manage", then select "Compact and Repair Database". The usage dialog from there is straightforward. One that'srun, try opening the database again and opening the table as well.
Jul 15, 2009 | Microsoft Office Standard for PC
Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Network path not found
I am not sure if your router is the problem here. Check the settings on your laptop.
Right-click My Computer
click Manage
click Services
scroll to Routing and Remote Access
left click Routing and Remote Access
click Properties
click (General tab) Startup type and select Disabled.
Also stop the service.
Also make sure that all computers belong to the same workgroup.
See if that corrects your Network path not found problem.
What do you mean by
"wireless printer is also not working"?
Does the printer work if it is connected to your router?
Have you checked the network settings on the printer (especially the IP address)?
If not, please let me know - come back here and leave a comment and a copy of your "ipconfig /all" output - I'm happy to help.
May 28, 2009 | Linksys Wireless N Gigabit Router
Computer freezes when printer is on
I had this problem, and the only way to stop it, was to uninstall all the drivers for all of the other printers and scanner that had been previously attached to my computer. That and three system restores and 5 reinstalls of the AiO software, that has yet to install the Home Center or the Help files! I can't customize the printer but I can use it now through WIndows programs.
Jan 11, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Computers & Internet Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
