Question about Toshiba Televison & Video
When TV is inititally turned on the picture is perfect. After a few minutes or more, the picture becomes blurred. On a scale of 1-10 (10 best) the view is about a 6-7. What can I expect? What are the cost estimates? Sometimes when I tap on it, it will work fine for awhile and then go bad again. Very frustrating as we like the picture when it works.
    Brigadier General:
  • 8,909 Answers
That sounds like the focus is going out of specification due to a dry solder joint or bad connection.
Checking the EHT distribution box for a bad connection could be fruitfull.
Use utmost care as lethal voltages are at this point!
If the picture recovers slowly it could be a tube base problem.
I don't think it will be much other than the Focus voltage is going up and down.
Posted on Jan 02, 2011
BLURRED PICTURE AT THE BEGINNING WHICH GETS CLEAR AFTER A FEW HOURS
Check and replace the back-light inverter board. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy.
Jan 24, 2014 | Panasonic Flat Screen 21 Inch Multisystem...
Blurred and fogey picture with same samsung model la32c450. Can turn of tv to get clear picture back but after a few minutes problem returns
Hi Paul,
Do you get clear OSD. If yes, it is the main board, if not unfortunately it has to be the lcd panel. Good luck.
Jan 04, 2014 | Samsung LA32A450 32 in. HD-Ready LCD TV
I just bought a Dynex LCD TV. It seems to work
Suggestion: This TV is new and part/labor are covered by the Manufacture Warranty. Contact Bestbuy for service options. It sounds like you have a panel problem. I hope this was helpful, best wishes.
Jul 13, 2010 | Televison & Video
Blurred appearance when turning on
There are few dried capacitors at the power board. They need to be replaced.
Feb 24, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Black screen, but perfect sound
all you need to do is change the lamp...go to a tv repair man tell them the model/serial no. and the lamp code..you will find that on the left had side of you tv as you are looking at the screen,,,that should do it for you. good luck
Jun 02, 2009 | NEC PlasmaSync 50MP1 50 in. Television
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Green Screen
It can be a result of dry solder joints on the CRT base PCB, the PCB you see on the end of the CRT. Resolder all the joints on that board perfectly and thouroughly and this will be alright. Good luck.
Jan 14, 2008 | Samsung TXN3245FP 32" TV
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Televison & Video Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
