Question about Frigidaire FMV156D Microwave Oven
FMV 156DSB Timer and light works, but does not heat unless you push up on bottom of door.
    Brigadier General:
  • 8,909 Answers
Slacken off the lower hinge screws and re set the door to the correct height, then tighten them back up.
That should sort that out.
Posted on Jan 02, 2011
Frigidaire microwave FMV156DSB. Turntable don't turn and no heat. Clock, keypad, light and fan works. The guys above looks like they right about either the door or the switches for the latch. This model does have two switches and a fusible switch. Pushing up a bit on the oven door from the bottom right corner when its closed make mine turn on if you set it to cook. Switches numbered 8(x2) on the schematic has part number 5304440026 $18.05. Fusible switch has part number 5303319559 $30.36. Have'nt changed them because it may be the door hinge is bent since the door latch is made out of plastic. Also looks like a real pain to take apart just to get to the switches. I will try to bend the door hinge to see if it fixes it.
Posted on Dec 18, 2011
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door alignment is off, will count down but won't cook
My microwave will not heat up its in a defrost mode. How do I change it?
Jul 27, 2013 | Sharp R-1505 Microwave Oven
We have had this microwave for 7 years. Not had any problems until about six months ago when the volume went way down when you push the buttons and timer, but still heated. Then all of a suddon it does...
Remove the cabinet ... check the door safety interlock switches for proper operation. Most of the time, no heat problems can be traced to the oven thinking the door is open. These switches tell the oven if it is open or closed. If they are faulty ... well ... the oven thinks the door is open and will not turn on the heat.
Make sense?
Thanks for your question today.
Feb 06, 2011 | Whirlpool MH1150XMQ Microwave Oven
Frigidaire FM156DSB 950w #7G63610032 light and timer works but microwave will not come on. When you push start it just clicks and does nothing. You can push up on the door from the bottom and microwave...
I have the same problem with ours! The light will come like it should but the microwave will not start until we hit the upper part of the door handle. Any advice?
Jan 21, 2011 | Microwave Ovens
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Maytag Over-the-range microwave runs but does not heat Model MMV4205BA. Light works, turntable works, timer works. But no heat
Please remove the cover and check the door safety interlock switches. Check with a contunity checker or a volt ohm meter.
What happens is thjis: when the oven is running ane you open the door, the tiny contacts in these little swirtches arc and burn. Eventually, the switches fail. When this happens, the oven doesn't know the door is closed. When The door is open, the oven will not turn on the magnatron. No magnatron, no heat.
It could be the start capacitor, but not likely compared to the switches. Dont try to service the capacitor unless and until you understand the danger.
Thanks for posting your question at FixYa.com - please vote.
Thanks
a
Nov 14, 2009 | Microwave Ovens
Microwave GE MD JVM140K Spacemaker yr= 1994 NOHEAT, DISP/TIMER OK
Call GE answer center 1-800-626-2000
ask for tech help
Have you model # off your data plate ready.
May 10, 2009 | GE Profile Spacemaker Over-the-Range...
Sharp Carousel will not turn on unless I lift gently on the door.
the door interlock switch needs adjusting or replacement
Mar 26, 2009 | Sharp R-1480 Microwave Oven
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Frigidaire FMV156D Microwave Oven Logo
198 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
