Question about Amana DK25 Dehumidifier
I LOST MY WATER CONTAINER (BUCKET) FOR THIS DEHUMIDIFIER - PART # R0211567 - I checked a couple of places they said it is discontinued. Any idea where I could find this part ? TY Constantin
  • 121 Answers
SOURCE: GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Posted on Jun 24, 2008
  • 3 Answers
SOURCE: water leaks around the bucket even the bucket is in place-bucket collects a little bit of water
It sounds like you need to check the drain under the cooling section. It can fill with dust, lint, cat hair, spiders, etc. and prevent water from draining into the bucket. First, unplug the unit. Don't do anything with AC power present. Then, remove the 2 screws under the front panel where the air filter slides up in and pull off the control panel. There are "snap" latches in the plastic near the top that can be (are) hard to undo, so be careful. You might want to have work gloves on because of sharp edges. Prying with a screw driver will cause permanent dents in the plastic. Also, there is a small, sleeved bunch of wires that goes up the left side to the operator buttons and display. Be careful not to damage it and the circuit board it goes to. Set the front panel aside, wire attached. There is no need to disassemble any of that. The drain is a small 3/8" hole in the black plastic floor of the cooling area at the front, right side. It seems to have a fitting for a hose that feeds through to the back of the unit. Clean any foreign material from it and everything else. Test it, with the bucket in place, by pouring some water in, if you want to. Then clean the dust off of everything so it looks new. Don't get the circuit board wet. Re-assemble, being careful with the front panel wire so it is not pinched and does not prevent easy removal/installation of the filter, and it should be OK.
Posted on Sep 22, 2008
SOURCE: Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Posted on Oct 07, 2008
  • 52 Answers
SOURCE: Kenmore Dehumidifier Isn't Running
It sounds like you have power to the unit but a component is failing to start the system get an AC tech to check it.
Posted on Jun 09, 2009
  • 51 Answers
SOURCE: Dehumidifier won't start
there should be a trip switch that is not resetting remove the bucket and find the switch. gently lift it up and try again
Posted on Aug 13, 2009
How much water do I put in water bucket on this thing?
You don"t put anything into the bucket. A dehumidifier will fill the bucket for you.
Jan 13, 2013 | Whirlpool AD50USL Dehumidifier
Full light is on and therefore it will not run even though there is no water in the container.
Generally, when this occurs, it is a result of misalignment of the placement of the water collection bucket. Remove the bucket, an reinstall it into the dehumidifier making sure that it makes proper contact with the bucket safety trigger switch. If you do this while the unit is turned ON and the humidity extraction level is set low enough, the compressor will turn ON when the bucket is properly installed. Also, check the float valve in the bucket (if yours has one) to make sure it is not stuck in the 'UP' position.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 07, 2011 | Maytag M7DH45B2A Dehumidifier
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 26, 2011 | DeLonghi DE500P Dehumidifier
It runs but no water is in the container
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 02, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a AD50USR1 Dehumidifier. I filled the bucket with wayer, but when i slide it back ito place, the bucket is not pushing that button on machine to operate it. It says to fix or adjust bucket. How do...
Why would you be putting water INTO a Dehumidifier??
The idea of a dehumidifier is to EMPTY the bucket, then the machine takes moisture out of the air, fills the bucket and you empty it again.
Are you sure you need a dehumidifier and understand how they work?
Aug 02, 2017 | Whirlpool Dehumidifier Dehumidifier
Auto shut off prevents dehumidifier from working even though there is no water in container.
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Dec 02, 2010 | LG Goldstar 30-Pint Dehumidifier
Dehumidifier runs but doesn't collect water also the full light won't turn off and the container is empty. Float is in it.
heatman101
Jun 29, 2010 | Fedders A7DH45B2A Dehumidifier
Our dehumidifier keeps running without any water coming from the unit. The pipeline to the outside is clear. The container for excess water is dry. Is the unit gone?
Yes it seems that it is toast....just to be sure check out this tip...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 14, 2010 | Goldstar DH5010B Dehumidifier
Amana DK25 Dehumidifier Logo
29 people viewed this question
Top Amana Dehumidifiers Experts
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
