Vista will not be the culprit here. The beep most likely meens that thee is a problem with the memory stick itself, especially if it boots normally when you take it out again. Motherboards are mostly designed to take identical sticks of RAM in pairs (Same brand, same model, same amount of memory) and sometimes, you will find that different manufacturer's RAM will not work in some systems.
Check to see if the RAM stick you are putting in is the same brand/model as the one already in. Also check to make sure it has the same amount of RAM on it. It could also be defective.
I hope that helps
Hi, the ram sticks are from Crucial and they are identical and they are not defective. They each work if installed seperately.
Thanks for trying!
