Question about Asko T761 Electric Dryer
ASKO T760; Drum "Thumps" rapidly
  • 3 Answers
I have replaced the drive belt and rollers, to replace front support rollers you need to take drum out to gain access to them. the part that takes the longest is removing rear panel, the 4 screws around the drum bearing and the screws that hold heating element to the rear panel. Then you can rotate rear panel out of the way, having a small stool or chair for it to sit on makes it a whole lot easier. With this out of the way you can remove drive bely from drum and lift it out of the way. The rubber rollers sre held in by bolts with nylon nuts on the front, be careful when taking out the bolts that you don't knock the nut out of its holder, if this happens you will need to remove the screws around the inner door opening to be able to put the left side one back in. I had the dryer laying on it door to remove the drum an belt, then placed it in the normal position to change the rollers.
Hope this helps, took about 45 minuetes, I'm not a appliance tech.
Posted on Mar 12, 2011
How to Replace the belt for a Asko T700 Dryer?
I have a T760, and the way I do it is to take the top off (3 screws in the back and slide it out from under the front lip), take some pics of the wiring so I'll know where they go (they're marked, but pics still help), and take the back off (perimeter screws). The drum bearing is mounted in the back, so I have to tap the drum shaft thru the bearing (take the washer off and put the nut back on so it is flush with the end of the threads). Asko has a special tool to hold the drum in place while the back is off, but I made one out of a coat hanger (a hook on one end to hang on the lip of the drum, bend a couple of right angles to fit thru the holes in the front panel, make it before the back comes off). The real hassle is holding the drum in place while reinstalling the back and the tool does this nicely. The belt has a spring loaded tensioner, make sure the wheel and bearing are ok, put it back together, and you're back in business...
May 10, 2012 | Asko T700 Electric Commercial Dryer
Asko T760 Dryer - Computer Screen Blank
you have either a frequency related issue or there is a lot of t.h.d. total harmonic distortion on the line, this will raise cane with electronics, I would try a power line conditioner on the dryer power circuit
Jul 30, 2009 | Asko T761 Electric Dryer
Replacing drum support rollers on a Asko T760
http://www.repairclinic.com/Asko-Parts
Apr 07, 2009 | Asko Dryers
Asko W640 - sporadically says motor fault and won't run, or, won't stop running, gets stuck on the spin cycle. We've had the motor fault problem before, but this "running on" issue is...
I would say the won't-run problem is separate from the run-on problem. You can live with the run-on problem -- probably a fault in the controller. Unless it's a faulty code, the motor-fault light probably means the motor is overheating. That can be caused by anything that causes it to work hard, such as a stuck pump.
Nov 26, 2008 | Asko Washing Machines
I have an asko dryer model t760 that overheated the other day. it did finally trip the overheat protection switch on the back, but it did get hot enough to distort a few plastic pieces and put flat spots...
Try taking the lint filter out and gently washing it with a soft scrubber. The screening is very fine and it might look clean to sight but might still need a more thorough cleaning.
Aug 25, 2008 | Asko Dryers
ASKO t700 dryer thumping sound
usually whin you get one thump (or a quick double thump) you have a dent in the roller surface of the drum itself. Easiest way to check this is to unplug the unit and take the top off by removing the 3 torx screws in the rear, then lifting the top off. Once the top is off look at the very front edge of the drum as you rotate the whole thing by hand. If you see any irregularities on the surface, thats your problem. If you see nothing it could be a bad motor or roller, but its unlikely if its happening in the same place on the rotation evry time. What has usually happened with dents in the surface of the drum is that the unit was set down too hard (or dropped) and the wheels it rests on dented the metal they ride on. If thats the case the only solution is to replace the drum or live with it .Good Luck!
Feb 10, 2007 | Asko T700 Electric Commercial Dryer
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
Asko T761 Electric Dryer Logo
383 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
