Question about Nokia N97 Cell Phone
What is the method to switch off the bluetooth ?
    Guru:
  • 200 Answers
Click on the phone menu button
click on the settings menu
then navigate to Connectivity
to on it click on options-now select off. to on it while it is on, you will see on instead of off.
Posted on Jan 02, 2011
What is bluetooth phones
Hello
Bluetooth is a short range wireless communication method that allows a phone to communicate with a set of headphones, an earpiece, an in-car module (provides "hands-free"), an external loudspeaker, or any other bluetooth device by "pairing" the devices together so that the connection requirements are remembered and can be activated whenever the paired devices are within range of each other.
An example is perhaps easiest to understand. I have a bluetooth kit in my car which plays through the in-car stereo. As soon as I start the car engine and therefore give power to the unit via the ignition switch, it automatically finds and links to my Samsung Galaxy in my shirt pocket.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 27, 2015 | T-Mobile Cell Phones
Turn wireless
You may have a small switch on the side of your laptop that turns on/off wireless and/or Bluetooth. Or you may have to use "fn" keys to do that. If you've tried both methods and nothing happens, check that your devices in Device Manager have good drivers installed.
Jan 14, 2014 | HEWLETT-PACKARD Hewlett Packard BLUE HP...
I cant connect xtm-1200 bluetooth device to my system
Ok, so you've successfully 'paired' your Bluetooth Headset with your computer. Now we're going to 'connect' the Headset so that you can start using it. There are two ways in which we can 'connect' our Headset. Both of the methods I'm about to tell you about achieve the same thing so really it's up to you how you want to do it.
Method 1: Note: The first time you try the following method, your Bluetooth Headset may not be visible in the context menu we're about to bring up. 'Right-click' the Bluetooth icon in your Windows taskbar and highlight 'Quick Connect'.
Note: If you're unable to select 'Quick Connect', it's likely that you're Bluetooth Adapter isn't switched on so you should firstly, 'right-click' the Bluetooth Icon and select 'Start the Bluetooth Device'.
Jul 29, 2011 | Computers & Internet
I am opening bluetooth but it is again going back to conetivity and bluetooth is not operating
Read all :
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Nov 27, 2010 | Nokia 6600
Presario r3000 when i click on bluetooth icon it just says no devices found what can i check
If you are not able to connect or configure the Bluetooth then please check the steps and the link below which will help you to connect it properly.
  1. Click Start , click Control Panel .
  2. Click Switch to Classic View and click Bluetooth Configuration .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00583172&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN#c00583172_M4
If any issue persist, please get back with product no. which is at the bottom sticker.
May 31, 2010 | Compaq Presario R3000 Notebook
Bluetooth Activation Toshiba satellite pro L300
Method 1 :  FN+F8 function should enabled the BT and should stay in this position. Then the BT could be always on.
Method 2 : Start menu -- Run -- Type " fsquirt.exe " without quote. it will automatically find the drivers and activate your bluetooth only if you have the Bluetooth driver installed.
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
Is there any method to surf internet on Blackberry Pearl 8100
best method i feel is that you can connect it to the pc via a USB and can start surfing
via bluetooth also you can surf using your computer's internet connection but before that you may have to change the settings in the bluetooth configuration side to allow internet sharing to the other device
cheers
pls rate if it was any help
Jul 04, 2009 | RIM BlackBerry Pearl 8100
My nokia 6600 is sending bluetooth messages on it`s own
hi its a very common problem with 6600. u should flash ur mobile from a certified mechenic.OR u must try this method: first switch off ur mobile and switch on ur set while pressing (star key),(dial key or green key)and(number 3 key) till formating screen appear.after appearing formating screen leave the button and let format ur handset.
plzz rate me
Dec 22, 2008 | Nokia 6600
How to remove bluetooth from nokia mother board for 6600
you need the following
tools and material
Need a Hot air device'
twezzer'
flux
dismantle the unit and put the flux around the bluetooth,
re-heat the bluetooth w/ the hot air device or a infared soldering device' wait unti the solder led around the bluetooth is soldered...
Jan 23, 2008 | Nokia 6600
Nokia N97  Cell Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
