Question about KitchenAid KUDS01IJ - Multiple Color Dishwasher
ON A KitchenAid model KUDSo1IJ dishwasher: A number of cherry pits have gotten into the water intake sump, so I NEED TO REMOVE THE COVERS FOR THE WATER INTAKE , after removing the lower spray head, I see three torx screws and a clip for the rear tube for taking water to the upper rack Also where can I access a repair manual ?
  • KitchenAid Master
  • 2,605 Answers
Welcome to FixYa.
To get a repair manual you may find one at the link I provided here...
http://allrepairmanuals.com/appliance.php
As for taking the unit apart, try this.
You`ll need to remove the lower spray arm and then the filter below it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
ON A KitchenAid model KUDSo1IJ dishwasher: A - a6dcf7f.jpg
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress thON A KitchenAid model KUDSo1IJ dishwasher: A - 87fb0d6.jpg i.e.
5fON A KitchenAid model KUDSo1IJ dishwasher: A - 333a8e1.jpgclass=
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find either alot of food debris, garbage, and hopefully the cherry pits etc. but also a cover with either a single #15 torx head screw or it will simply be held with a lock tab which must be pushed to one side and the cover will pull straight up and out. ( I haven`t gathered my own photo`s of this area yet, soon to come )
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can since you're in there anyway...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Jan 02, 2011
Kitchenaid dishwasher fills with hot water but doesn't wash
remove sump cover clean sump and change the chopper
Feb 21, 2014 | KitchenAid Dishwashers
Detergent opener does not dispense detergent during wash cycle. ive tried washing 4 different times and detergent sits undissolved in dispensor. dispensor door does not pop open either when i open door...
Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
If you have a tall tub KitchenAid then the sump may need cleaned.
Here are instructions that might help.But not knowing your specific model these instructions may not apply
A plugged up sump can cause a multitude of problems in a dishwasher, it can make the dishwasher not clean as well as it should, make the cycle run longer, it can create noises and redeposit food.
To clean the sump follow the directions below.
- Remove the lower rack
- Remove the lower wash arm (1) by turning the nut (4) clockwise (right) lift the arm off, there is a bearing (3) (small thin plastic washer) under the arm, be sure not to loose it. Lift the tab on the back of the feed tube cap (2) and swing it to the right and lift up, this may need a bit of pressure to release it.
- Remove the 4 screws (3) from the accumulator (1), lift off the accumulator. Remove 1 screw(7) from the cover (8) this is located down inside of the sump (4) on the left front side. Lift up and remove the cover (8), watch for glass and clean out all the debris from the sump and especially around the the area of the chopper and screen (6) which will be exposed with the cover (8) off. If the screen is blocked with debris that usually means you need a new chopper. it may be broken or loose and not doing its job.
Once clean reassemble and enjoy a dishwasher that cleans the dishes again.
Feb 14, 2011 | KitchenAid Dishwashers
How do you remove the lower spray arm for a kitchenaid dishwasher, model KUDP01ILBS6? I want to clean out the filter and mascerator.
I have put together instructions on how to clean out the sump area where the mascerator is on your model. Follow the link below and let me know if it is what you need.
KitchenAid Cleanout
Jun 21, 2010 | KitchenAid 24 in. KUDP01IL Stainless Steel...
My dishwasher makes a grinding noise when it runs. what could be causing that?
The problem most likely would be the seal for the pump has gone out and water has gotten into the motor bearings. In this case the best repair is to replace the sump assembly with the motor. The part runs about 150.00.
The other cause could be something has gotten caught in the sump that is too hard for the 'chopper' to cut up, this does not hurt anything other than to make noise, it may eventually flush down the drain, or you can disassemble the pump and clean it out. If you want to do that let me know, I will try and guide you through it.
Apr 24, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Aug 17, 2009 | Dishwashers
My Kitchenaid dishwasher failed to drain. Is there a way to fix this without calling in a repair person?
Check underneath and disconnect the drain hose that leads into the pump to see if there is something blocking it.  I had a similar problem and the technician found a cherry pit that was blocking the hose.  He told my wife that it was a common problem and showed her where to check so we could do it ourselves if it happened again.  We have not had to.
May 19, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Water is not coming out of the top water jets for dishwasher
What is the model of this KitchenAid diswasher and approximatly how old is it? On some newer, energy saving models water is alternated from lower to upper spray arms. But ...
Remove filter that is in the sump area beneath the lower dish rack. Screws will need to be removed to open the area up. Look for blockages and clean filter.
Reassemble and test. If problems remain, it is probably a failing pump motor and will require a service call.
Mar 30, 2009 | KitchenAid Dishwashers
Kitchen Aid Dishwasher seems to have gotten louder over the last month
time for a cleaning.. dont worry.. its pretty easy (but gross and probably full of broken glass)..
1) switch the breaker off at the panel
2) remove the baskets and unscrew the plastic thing holding on the bottom wash arm (remove the wash arm and check it for debris)
3) remove the top washer water feeder (there should be little clips that unclip it from the inside of the dishwasher).. and then it twists clockwise and pops out
4) you'll need a med flat head or better yet a star screwdriver set for the next part
5) unscrew the screw(s) holding down the plastic cover that covers the water pump intake inside the dishwasher.. this should expose a 'trap' at the front.. BE CAREFUL
6) start cleaning that out.. there should be everything from GLASS, to olive pits to cherry pits etc etc down there.. get it all!
7) while you're in there, there is another (delicate) cleaning task with the food grater/processor inside.. there is another screw that once removed, allows you to gain access to the food grinder.. there's probably debris in here as well.
8) once you've cleaned that out, take care to line up the grater into the right channel before you reinstall everything..
9) put everything back together, and run an empty load on hot with hot dry and it should be waayy quieter.. (and you'll be surprised at how clean the glassware is).
good luck
tpug
Mar 17, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Motor sounds like it is straining '
When you get a chance, please post the whole model number of your Maytag dishwasher here.
Because you are still getting clean dishes, you probably have debris (a bone or fruit pit) that has gotten down to the pump/impeller or the chopper area.
Remove the lower spray arm, remove the filter/sump assembly and clean everything out. With a flash light, inspect the whole sump area for debris. I bet you will find stuff there (beware of broken glass!) and when you re-assemble, the noise will ne normal.
Good Luck! Please post back what you find, OK?
Feb 14, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a LG dishwasher model # LDS5811WW is there a filter of some sort at the water intake? My water has be known to have sand in it . The dishes are not all washing some are some aren't.
No filter in these units. It is possible that sand has gotten into the sump assembly and is not allowing the vario motor to properly switch between the upper and lower spray nozzles.
Dec 13, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
KitchenAid KUDS01IJ - Multiple Color Dishwasher Logo
439 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
