Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
The light in my whirlpool ed25dqxbw00 refrigerator isnt working...i replaced the bulb...no luck...i need to get to the switch so i can ohm it out but i cant figure out how to get the cover off the front where the bulb goes in...i took 6 screws out but it was still on there pretty well...any ideas???
aborcass
  • 2651 Answers
SOURCE: whirlpool refrigerator
unitsdworking though just no lights in refrig compartment??? if so i would pull unit out nad check laft side bottom of unit for contoil board, remove it and chances are you see a burn mark on one of the circuit, if so youll need to replace it
Posted on Feb 26, 2008
SOURCE: HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Posted on Jun 30, 2008
SOURCE: water filter replacement
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Posted on Oct 25, 2008
  • 5 Answers
SOURCE: The light and digital controls on the refrigerator side dont work
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
Posted on Dec 31, 2008
aborcass
  • 2651 Answers
SOURCE: I need to replace the water line tubing in the
the front dispensor panel can be removed by lookin under the panel you see too little spaces in which ti insert a screw driver,by pushing down on the top, you cantwist the screwdriver in the opening eleasing the tabs, and simply lifting off the top tabs, dependingon model you may need to un plug a wire or 2.. the tubing should be able to be removed be releasing the connector undeer the door and simply refeeding the new hose back into unit
Posted on Jan 27, 2010
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
Inside light went out...replacing bulb did not work, any help or advise? thanks! Mike
Many times when the inside light fails to operate...it could be:
(1) A bad bulb ...replace with a known good one.
(2) Bad connection of the light bulb in its socket.
(Remove the bulb and spray the socket with WD-40 Spray Lubricant) then...
(3) Replace the bulb with a known good bulb..use a dry rag to securely tighten the bulb in its socket.
(4) The "Door Switch" could be bad. Replace bad "Door Switch" with new one.
Hopes this helps....Good Luck! ...... HandyHenry
Mar 24, 2011 | Whirlpool Refrigerators
HOW TO CHANGE THE LIGHT BULB IN THE REFRIGERTOR
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Refrigerator light is not working. I changed the bulb with no success. Is there something additional that I can do?
How about the door switch? If you can use a volt meter, take the bulb out, and place the red lead on the inside center button of the bulb holder, Be sure not to touch the side of the holder. Touch the black lead to the outside of the holder. Is there voltage? If not, the switch is bad.
Jul 13, 2009 | Refrigerators
Whirlpool side-by-side - Model ED25RQXYW02 Light burned out on fridge side - replaced bulb but still no light? Is there also a fuse someplace? Thanks, Dave dwnoble@yahoo.com
What a compliment. Thanks, Dave!
I was off on the ohms, though, I was figuring on a lower wattage bulb -- the higher the wattage the lower the ohms.
May 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Mar 04, 2009 | Whirlpool Refrigerators
Lost light Whirlpool Regal refrigerator
two ways might first un plug the unit take the bulb ou and with your finger pull up on the contact inside the light socket ***** the bulb back in and try it if that doesn't work unplug the unit and with a mall screwdriver pry out the switch un plug one wire and with a meter check it to see if its working right or just replace it
Mar 12, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
