Question about Dryers
Hi My dryer makes a banging noise when running.... I got the top off but still cannot see anything.What is the next easies panel to take off?
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
Problem with tumble dryer that has started making loud noise.
Dryers are designed to operate in one direction. Some models turn clockwise and some turn counter-clockwise. Do not run it backwards. The direction of air flow will be impeded or reversed.
Mar 07, 2017 | Whirlpool Dryers
My tumble dryer is making a loud banging noise when it turns. It is on for a few minutes and seems to happen when it switches to turn the opposite way
It will be worn slipper pads that are around the front edge of the drum. If your dryer can run when inverted that will stop the noise until the pads wear down again.
Purchase some new slipper pads and remove the back panel of the dryer moving the drum back about 1 inch. You will now see were the slipper pads are fitted around the inside edge at the front.
There will be about 6 of them, you can take the top ones and move them to the bottom. This will also stop the banging until they also wear down.
Oct 24, 2015 | Dryers
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
I have a Maytag Intellidry Gas Dryer Model MDG8057BWW. When it runs, it makes a banging sound on the left side. I can feel the banging with my hand on the frame. What can this be? Is the dryer safe to...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 15, 2010 | Maytag Dryers
The dryer makes a loud banging and squealing noise. The top back panel on the dryer gets very hot as do the top of the dryer
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 09, 2010 | Dryers
Dryer makes banging noise
heatman101
uioiotusdds
Jan 30, 2010 | GE DBVH512GFWW Dryer
My dryer makes noise when running
heatman101
hggf
Jan 18, 2010 | GE DHDVH52GFWW Gas Dryer
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud banging noise while drying
the Idler bearing maybe going. its fairly easy to replace. go here http://www.repairclinic.com/Maytag-Dryer-Parts?s=b4a8c203
the part is cheap and i will show you how to remove the front door and replace the bearing.
May 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Oct 02, 2006 | Maytag MDG9206 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
