Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
I bought a LX30H (ML104354)dishwasher from a restaurant owner to install in my residence. According to the faceplate, it is rated for 120/208 (3W) single phase at 43.6 amps. According to Hobart's specs, it is rated for 120 / 208 (3W) / 60 / 1 * or 240 / 60 / 1. My question has to do with the line voltage rating. If my residential voltage is 240V and the unit is truly only rated for 208V, this would probably burn out the motor, etc. I'm not sure if the specs imply that there are two different versions (208V and 240V) or that the unit will operate at either voltage. Does anyone know?
  • bbtaylr Jan 16, 2011
    According to a Hobart tech, the motors are 120V, so it doesn't matter if 208 or 240. The only 208/240 issue is the heating elements which could have a shorter life if rated at 208 but run at 240. Replacement elements rated for 240 can be bought through Hobart.
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
  • 6 Answers
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Posted on Sep 12, 2009
Testimonial: "You were right! can you help mr with a P2 error code?"
  • 6 Answers
SOURCE: This dishwasher is older than most living people
This unit is a dinosaur. The 3-phase converter had to cost twice as much as the unit. Best solution - turn the power off to the 3 phase converter when not in use.
Better best solution - find a newer unit that will be repairable should it need service. Virtually nothing is available for the AM9 series of dishwashers.
Suggestion - talk to a commercial dishwasher chemical provider that leases dishwashers. They may have a surplus unit that they picked up from a customer (that they leased a new machine to) that they may be willing to donate.
  • 110 Answers
SOURCE: lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Posted on Jan 13, 2010
  • 110 Answers
SOURCE: Hobart dishwasher model LX30H displays -5 on
by the way you're describing the problem, i would have to say there is something wrong with your control board. part#473173 can be bought @ any hobart office in your area. dont forget to vote
Posted on Feb 13, 2010
Testimonial: "Turns out it was mice eaten wiring."
Hobart lx30h leaking from bottom
This is a testing for the post on this web site, not a solution.
Mar 27, 2014 | Hobart Lx30h Commercial Dishwasher
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Feb 07, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dec 11, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
LX30H Hobart torsion bar adjustment
im a service tech for hobart,there are no adjustments,the torsion bar is broken.the parts arent expensive but installing them are tricky.
Dec 06, 2007 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
