Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Error Message: Did you change the bulb
My WD-52525 has a fuzzy screen with an error message, "Did you change the bulb". Can I be certain that replacing the bulb will correct the problem? What addition issues might be causing this error message and screen problem.
  • 927 Answers
Good Day, emoo;
You should be able to remove that message by pressing enter on your remote or front panel.
Good Luck, Big Irish.
Posted on Jul 10, 2008
I replace the bulb and I'm getting a blinking error code 3 4. How do I fix? Mitsubishi WD-52525
That code can often be caused by failed capacitors on the power board which will cause the 34 error for lamp abnormality. The V26 Power repair kit at www.tvrepairworld.com may fix that issue. The kit contains the replacement capacitors and has the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 blue screen on all inputs
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Error message: check connections or power-the connections for RGBHV or YPrPb may be invalid. The screen is a two tone blue and is flashing.
DO NOT do anything to your Mitsubishi WD-52525 until you read this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html . There has been a worldwide problem in computers and TVs over the past several years with faulty electrolytic capacitors (from Taiwan) that decay, dry out, swell and die. The power supply is often the first component to go bad, but other systems also degrade over time. As the forum explains , this problem is widespread in these sets causing multiple types of display problems after several years of use. Mitsubishi is aware of the problem and will cover most of the cost of repairing the chassis, even years out of warranty, but apparently ONLY if you get an estimate from a Mitsubishi certified repair station and contact their customer support BEFORE doing any work on the set. I just followed the recommended procedure on that forum and Mitsubishi is covering half the cost of my $700+ repair when my 3+ year-old set recently died and showed only a blue screen. I'm not sure if this is your problem, but it might be.
Apr 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Error message
Good Day, drdeath57;
Make sure your air vents are clean but more than likely you should suspect the TV's Lamp Thermal Sensor
Aug 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Unable to receive input device signal
Can you post a picture of the screen so I can properly diagnose it. It sounds like the caps on the FMT PWB but a picture would help me be certain.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Display problems
Sounds like bad 1000uf capacitors on the FMT board there are 3 100ufs on that board that can cause that symptom
May 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Says bulb has to be replace.
If your Tv is less than a year old you want to get ahold of Mithubisi NOW! There are two upgrades if you can call them that that adress the overheating and blocked airflow, And if the lamp needs replaced I'm sure you would rather have Mitshubishi pay for the 350.00 lamp than you
Feb 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52525 no picture or sound
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
