Question about McCulloch 4 Ton Electric Log Splitter # FB4052
Hi. I have a Woodchuck fb4052 log splitter, and after I split a log, I have to fiddle with the handle to get the ram to retract. I don't have a manual, maybe the fluid level is off, but don't know where it should be, or what kind of oil to use. If I push the lever down, it will creep back, and if I raise the handle a little, it will speed up a bit, but with the handle all the way up, it stops. Maybe the check valve? Thanks, Mike
I beleive there is an hydraulic release valve that must be in the open position for this to retract
Posted on Nov 20, 2011
Hydraulic oil spewing from fill cap
http://www.northerntool.com/images/downloads/manuals/1114.pdf
Check the assembly and note that the ram returns to its position when you activate it EVEN if you release the valve handle. Also make sure you don't have too much fluid in the reservoir.
Jan 22, 2016 | Northstar Horizontal/Vertical Log Splitter...
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
My mcCulloch woodchuck log splitter FB4052 circuit breaker keeps tripping why and were can I get one if that's the problem
Look for a short in a wire first if not one found remove it and take to lowes they should have one
Sep 07, 2014 | Tools & Hardware - Others
Just got a log splitter cantget started motor running it moved and blew fuse
Hi, not much info to go on here, but;
have you ensured that your outlet automatic fuse (if applicable) will handle the current of the electric motor? Check ratings. If motor rating is close to automatic fuse limits, you will need a "slow" type auto fuse or use a larger capasity outlet. This the first thing to check before looking further at the splitter itself, assuming that it is the fuse of your outlet that you blew?.
Kjell
Jul 14, 2011 | McCulloch 4 Ton Electric Log Splitter #...
5 ton electric woodsplittr wont return to start
look for a limit switch that might have debri in it not allowing it to read properly.
Mar 15, 2011 | McCulloch 4 Ton Electric Log Splitter #...
I have a 4052 mcCulloch 4 ton log splitter. What kind of oil does it take for the hydraulics
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Nov 06, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Splitter (2 years old) motor won't shut off.
First of all, I hate to, but have to ask, have you verified oil level is up to proper level? Have you checked power at directional solenoid when handle is moved to different directions, as well as released? Obviously when handle is in stop position, there shouldn't be power to motor in either direction. I can't see exact model, or design obviously,but that would be a good place to start.
Jan 31, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Was just curious if the 4ton 2hp electric wood splitter was 110 or 220...hopefully 110 as I just ordered it for hubby!
Sorry but I think it will be a 220V motor.
They do not advertise the voltage very well and I had to do some digging to find that the motor pulls 12.5 maps which would make it a 220 v motor. At 110v a 2 Hp motor would be pulling 20 amps or more which would still make it too much for most household circuits.
Running a new line for your splitter should not be a big project for most electrictians... Also if your husband has a gas generator most of them will run that splitter and then it would be portable...! Just load up the generator and the splitter and he can split anywhere...
Heatman101
Dec 30, 2009 | McCulloch 4 Ton Electric Log Splitter #...
McCulloch 4 Ton Electric Log Splitter # FB4052 Logo
504 people viewed this question
Top McCulloch Tools & Hardware - Others Experts
ArcFlash
Level 1 Expert
Tom Chichester
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a McCulloch Tool and Hardware - Other Expert? Answer questions, earn points and help others
