Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
I purchased a jenn-air model JDR8895AAS LPgas range and want to convert it to natural gas.What do i need?
    Sergeant:
    Champion:
  • 342 Answers
You may need to not change anything but i have not experienced that yet but look around and see if you pull anything up on google
Posted on Jan 02, 2011
Need help on converting my jenn air from natural gas to Lp! the location of the new orifice's and what size goes where??? I bought a conversion kit from AppliancePartsPros! Stove Is a Jenn air jdr8895aas
give the kit to the gas fitter that you will get in for the job
gas conversions are not a DIY job as it is not just the jets but the positioning of the air shrouds for correct burn
Jul 19, 2017 | Jenn Air Kitchen Ranges
How do I convert a Jenn Air PRG 4810 from natural gas to lp?
Many gas stoves anymore have adjustable orifices. and they just need to be adjusted to propane .
Mar 09, 2015 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
How can I disable Sabbath Mode on my Jenn Air JDR8895AAS
Sabbath Mode on this model can be disabled by pressing the "CLOCK" button and holding it for 3 seconds. "SAb" will then flash for 5 seconds, then return to normal display. Sabbath Mode will also automatically turn off after 72 hours.
These instructions are listed on page 16 of your owner's manual. If you no longer have a manual, you can obtain a replacement copy at managemylife.com. Just enter your model number under their "Manuals" link and you will find the owner's and installation manuals available in .pdf format. You can download or print a copy for FREE.
For your convenience, here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/3891/JENN-AIR-Range-Electric-Gas-L0411320?brand_name_search=jdr8895aas
If you require additional assistance, please post back and let me know. I hope you find this information helpful.
Oct 25, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Several Gas Burner Igniters spark every 5 seconds even when all burners are turned off. Jenn-Air Dual Fuel Range JDR8895AAS Help, and Thanks! -- Larry
hi could be a short on the ignition switch of the spark box is stuck in the repeat mode disconnet power and see if this helps
Jan 23, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Parts for converting Jenn-air svd48600w frin LP back to NG
try google jenn air have a wed site or a shop that sells that make
Jan 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Why does the range give us a caution that the range has been setup for propane.
stove comes from the factory set for natural gas, be sure your not reading a sticker that would affix to the range after you convert it
Mar 22, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
100 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
