Question about Video Game Consoles & Games
My ps3 contorler not working - Video Game Consoles & Games
  • 943 Answers
The main reason why a ps3 controller will not work are limited.
First, it is common for your battery to die or run flat and then require you to charge it using your game usb cord.
If you have tried this and it still doesn't work, then your controller battery have probably exceeded their life-span and as such ,may not even charge or come on. This depends on the amount of time you have used it and if it has been more than 3 years, you may need to change it.
Lastly, you can try resetting it by looking for a tiny pin hole under the controller and use a pin or a similar object to press it.
This resets the controller and clears all errors in it programming or configuration.
Hope this solution was useful to you? Please comment for more information and thank you for using the fixya website.
Posted on Jan 02, 2011
  • Gavin Mulvany Mar 22, 2011
    Hi I have the same problem but it doesnt work on a laptop either(not picking it up but picks up others controllers), i also tried a new battery, the controller seems to be just dead. any help would be greatful before i buy a new one
  • Alex Edoh
    Alex Edoh Mar 22, 2011
    This may be a little complicated. If you can give it to a repairer to help you check it real quick, maybe there are some disconnections on the board. It shouldn't be very expensive to do this.
WAY DOES A CRUISE CONTORL WORK ALL THE TIME BUT CUTS IN AND OUT BUT IT IS STELL WORKING
if it cuts in & out then it is obviously not working properly
Nov 11, 2014 | Cars & Trucks
Cvm2072sm1ss contorl panel
The keypad control board will need to be replaced, but due to the considerable cost, replacement of the microwave oven would be a better option.
Jun 24, 2012 | GE CVM2072SMSS Microwave Oven
Well that day there was an update 3.50 i down loaded it and then tried to go online would not work then i went to system settings entered somthing that go me this screen that said connect the contorller...
Hi if you go onto the ps3 website and down load the update onto a usb stick then re-install it again the chances are when you was downloading the update the 1st time you got cut off due to the maintenance the ps3 network was having and this has caused corrupt data on your hard drive so give that a try failing that you will need to get your hard drive formated and start again from scratch, you will lost everything on your hard drive though so be warned
let me know if you need further assistance ok
Sep 23, 2010 | Sony PlayStation 3 40GB System
Heater blower quit working
check all fuses to a/c and heater contorls then if all is ok pull theswitch out of the dash
you could hook a hot wire to the blower to make sure it works to
Feb 26, 2010 | 2007 Honda Ridgeline
Driver's side back window not working. I checked the window motor and it working fine. What next?
check wiring from drivers door to inside of car, wires sometimes split in half from door opening and closeing so much, if wiring is ok, the master contorl switch on driver door is bad.
Oct 02, 2009 | 2002 Ford Taurus
Husband has a ps2 controller that works when it feels like it
Sorry, I didn't quite understand the question, so are you actually using the wireless PS2 controller on the PS3?? Or it is for the PS2??
When i had a PS2, I brought a 'Logitech' controller for it and it worked well for about 6months, then after that the analogues started playing up and going funny. Same thing with the 'MadCats' PS2 contorller.
Now I have a PS3, and I just brought a new SONY PS3 Dual shock controller and works perfect. The logitech one is half the price, but i trust Sony more than other brands coz it is more reliable. I dunno if this helps, but if you're willing to spend abit more it's actually worth it.
You can check on eBay for an original PS2/3 controller which would cheaper than buying one in the stores.
Cheers~
May 13, 2009 | Logitech Cordless Precision Controller for...
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Mar 05, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Looking for Remote Contorl
well according from expierience. i used a different remote from the same model and it works. i believe the codes on the remote is the same thats why
Sep 30, 2007 | Coby DVD-224 DVD Player
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
