Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Scaning problem with TWAIN Scanner in Acrobat 9 When I select a Twain interface the Acrobat crashed and closed in any combination of "Data transfer Method" and "User interface" I used. On the other hand when I use WIA interface it works fine.but in this interface the Preset Profile of scanning are unavailable I have Xerox PE220 All-in-one Scanner and I installed the lates driver . My OS is Windows 7. Can someone help ??
  • 2072 Answers
SOURCE: Xerox M20I SCANNER
You can only do scanning on an M20i with a USB or parallel cable. That machine does not support scanning via an ethernet cable.
Posted on Oct 27, 2008
SOURCE: learn how to use my scanner on my xerox workcentre xe80
dont know how to scanner
Posted on Dec 08, 2008
  • 72 Answers
SOURCE: new toner xerox pe220 laser and it prints dark pages now
Make sure the electrodes between the drum unit and the printer is clean. Use a soft cloth or Qtip to clean, maybe slightly moisturized with vodka (not kidding). Vodka is actually perfect for cleaning most stuff that needs cleaning in printers, even the photosensitive layer on the drum if there happen to be dirt spots on it (gentle rubbing with Q-tip, very carefully).
Also clean the corona wire as per instructions in the manual, don't know your particular printer but there is usually some kind of knob on the drum unit that you are supposed to use for this purpose.
This should fix the problem.
Posted on May 21, 2009
  • 6 Answers
SOURCE: The OEMCFG.dll on Samsung needed
GO TO SAMSUNG/SUPPORT.COM
TYPE IN YOUR MODEL# AND DOWNLOAD THE DRIVERS YOU NEED.
Posted on Jul 15, 2009
SOURCE: Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Posted on Feb 28, 2010
There is no twain compliant device installed please install one and try again this is the error message was getting while scaning the page. please help me out..
First Install the Printer Driver.
if the Printer Unable o Scan & show the Error -- There is no TWAIN-compliant device installed. Please Install one & try.
Then U Follw this Tricks.It will solve Ur Problem 100 %.
Click on Add devicesClick on Start - search on scanner word -- click on View scanners & cameras -- Next - Selcet Manufacture Name & select the Printer Device Nname - next - Fiinish.
Aug 29, 2011 | HP Laserjet M2727nf Multifunction Printer
Reinstalled canoscan LIDE 200 on pc after we did a format its a Twain everything works except the toolbox when i try to scan a pdf says something about changing it to Twain we have uninstalled and...
Twain is the scanner interface program on the computer. Something is missing from the install or the XP system software. Double check to make sure you're installing an XP-compatible version of the scanner software. The program for newer versions of Windows likely assumes the presence of some software components that may not be there in XP unless the install program puts them in. Without those missing pieces, Twain won't load properly.
Aug 28, 2017 | Canon Computers & Internet
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
Scanner problems
Before you toss the scanner out, try uninstalling the Twain driver for the scanner and re-installing it. Go to Epson.com, select your country, select drivers & support, scanners and choose your scanner. This way, you will get the latest twain driver. If the new driver doesn't work, then the scanner may be toast, but I don't think so.
May 28, 2009 | Epson Perfection 1250 Photo Flatbed...
I have a Canon scanner 5000f. All of a sudden the computer won't recognize it and says it is "unable to select Twain Source." What do I do?
First you need to follow the instructions for installing the scanner. It is important whether you connect the scanner before the software is installed and whether you work from the new hardware found box or just install the driver as software. It sometimes varies between operating systems as well.
Sometimes the twain files can become corrupted. Since other devices like digital cameras use the twain files they aren’t erased with a driver uninstall or overwritten with an install. If the twain files are gone the driver install will also install them.
Uninstall ScanGear (I think that is the Canon driver software) and remove the scanner if it is still showing in device manager and control panel under scanners. Unplug the USB.
Do a search for twain and delete all you find in the Windows folder. There is probably a folder and several files – delete them all. Do not remove any twain files not in the Windows folder.
Dig out the instructions and reinstall the scanner exactly according to them.
Jan 14, 2009 | Office Equipment & Supplies
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Genius and Vista
There are two common ways to software-connect scanners
to windows:
1) The TWAIN driver interface
2) The WIA (Windows image acquisition) driver interface
WIA is a driver interface native to Windows:
http://en.wikipedia.org/wiki/Windows_Image_Acquisition
TWAIN is a driver interface specific to each scanner
Most new scanners should support both driver interfaces !
TWAIN is preferable, if you can find it, because it is tightly
coupled to the scanner's hardware design, and therefore offers
more functionality, which is hardware specific.
WIA, on the other hand, is more generic.
It will work with many different scanners, but with reduced
functionality, especially in the tools and setting available within
the scanner control window that pops up every time you try to
scan a document from within an application.
If you cannot find TWAIN, you may have to settle for WIA.
(if it will run with your hardware)
This biggest problem, of course, is VISTA itself, and it comes
in two flavors, depending on your computer CPU:
64-bit and 32 bit.
64-Bit Vista drivers are the hardest to find.
32-Bit Vista is a DOG, because the software is too bloated
to run on a 32 bit machine.
Fancy colors and GUI not withstanding, 100% of the added
"new functionality" within Vista is for the benefit of Microsoft
and the scumbags running Hollywood. Vista hi-jacks your
expensive hardware resources and slows down "YOUR"
machine at "YOUR" expense to promote Microsoft's
insestuous relationship with the Sony movie studios and
the RIAA.
I strongly recommend to all my clients to stick with XP for
now, and avoid Vista like the plague.
I do !
Martin
Jul 12, 2008 | Genius ColorPage Vivid Pro II Film Flatbed...
TWAIN interface stop transfering data
Try deleting and the reinstalling the software.
May 30, 2007 | Nikon Super Coolscan 5000 ED Film Scanner
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
190 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
