Question about Ngk Lfr5A 11 Spark Plug
My kia sorento 11 uses NGK R LFR5A 11 spark plugs and they are completely burnt at 8000kms this has made starting difficult is this normal?
I wish you could describe exactly what you meant by burnt. Because that could help with reading the plug and that in turn could give an indication of what is going on in the combustion chamber. If the thermal insulator at the center is completely melted for instance it could indicate that the mixture in the chamber is too lean and hence wearing the plug faster. If you have black deposits on the electrodes then the mix is too rich or there is oil leaking from either your rings or gaskets into the combustion chamber causing fouling and early destruction of the plugs, Mind you, I am assuming that your LFR 5As are the manufacturers recommended plugs otherwise their ratings could also affect what is going on in the combustion chamber and consequently the plugs. A rating of 11 for NGK is usually a cold plug and it will do well if the engine is frequently run at high speeds rather slow town start and stop idle situations.
Posted on Feb 02, 2011
  • Helios5 Aug 15, 2011
    The 11 refers to the plug gap which is 1.1 not the rating. the rating of the LFR5A is 5 which is a hot plug you can go up to LFR6A-11 and it will still be ok, I presume you do a lot of highway driving, because the LFR5A are mostly for city driving and short distances.
Does bkr6es-11 ngk sparkplug fit on 2010 acura tl?
No it doesn't fit your vehicle.Here's a link showing that it doesn't fit. NGK Nickel Spark Plug BKR6ES 11 5553 Advance Auto Parts
May 09, 2015 | 2010 Acura TL
Broken spark plug
If it is loose try pressing a piece of fuel hose against the plug and spin it out.
Jun 24, 2012 | Ngk Lfr5A 11 Spark Plug
What is the optimal gap for my LFR 5A v-power spark plug? I want power and fuel efficiency...Thanks
The correct gap will depend on exactly what engine you are using it in - they vary enormously - consult the owners manual
Feb 01, 2011 | Ngk Lfr5A 11 Spark Plug
How to replace spark plugs in a kia sorento
The 2006 KIA Sorento is a smaller SUV with a 3.5-liter V6 engine. This engine uses six spark plugs to run the engine properly. There will be three spark plugs on each side of the engine. All six spark plugs will need to be changed at the same time to ensure that all six are working equally. The spark plugs are in plain sight on the right and left side of the engine and have rubber wires connected to the top of each one.
  1. 1 Insert the edge of the spark-plug gapping tool under the meal arm in the center of the one of the new spark plugs and turn the gapper until the number .038 is in the center of the metal arm. Repeat this for all other new spark plugs.
  2. 2 Open the hood of the 2006 KIA Sorento and remove a rubber wire from one of the spark plugs. Use the ratchet and spark-plug socket to remove that spark plug from the engine.
  3. 3 Insert the new spark plug into the hole where the old plug was. Hand-tighten the new spark plug until you are certain it is seated properly, then tighten it further using the ratchet and spark-plug socket. Replace the rubber wire to the top of the new spark plug.
  4. 4 Repeat for all other new spark plugs. Once you have replaced all six spark plugs and replace the rubber wires to the tops of them, close the hood.
Jan 21, 2011 | 2006 Kia Sorento
Spark plug gap ?
Well Buddy, this is what the book calls for:
Standard NGK PFR5G-11 Hot NGK PFR4G-11 Cold NGK PFR6G-11 Spark Plug Air Gap 0.039 - 0.043 in Spark Plug Torque 14 - 22 ft.lb
Spark Plug Type Spark Plug P/N Standard NGK PFR5G-11 Hot NGK PFR4G-11 Cold NGK PFR6G-11 Spark Plug Air Gap 0.039 - 0.043 in Spark Plug Torque For all plugs (normal; NGK PFR5G-11, Hot; NGK PFR4G-11, and Cold; NGK PFR6G-11) the air gap on these plugs range from 0.039 - 0.043 in. This is a "5 thousandths" variation, and won't effect noticibly, the performance if you go with a "happy-medium" of 0.041 in
Also note that the foot pounds of torque are:14 - 22 ft.lb
Jul 27, 2009 | Nissan Maxima Cars & Trucks
Can't find where the spark plugs are located
The 2003 Kia Sorento with 3.5L V6 has the spark plugs located under black plastic covers in the center channel of each cylinder head. Several brackets, cables, and hoses must be moved out of the way to access them. The manufold air intake tube needs to be removed on the right bank.
The left cylinder bank has coil-on-plug assemblies while the right bank has more conventional spark plug caps with sealing assemblies to keep dirt/moisture out of the spark plug wells. The coil-packs are held with two 10mm bolts each and are difficult to get to. Use universal-joint sockets and an extension.
Takes about  2.5 hours to R/R spark plugs. The average do it yourself'er will take longer (usually). All electrical plugs are color-coded and/or indexed so it's pretty difficult to screw it up. The cruise control actuator cable is in the way on the left bank. Twisting the cable elbow upright releases it from the actuator allowing it to be bent sideways to gain clearance.
Good luck and hope this helps.
May 10, 2009 | 2003 Kia Sorento
CAN/T FIND THE SPARK PLUGS ON A 03 KIA SORENTO
The 2003 Kia Sorento with V6 has the spark plugs located under black plastic covers in the center channel of each cylinder head. Several brackets, cables, and hoses must be moved out of the way to access them. The manifold air intake tube needs to be removed on the right bank.
The left cylinder bank has coil-on-plug assemblies while the right bank has more conventional spark plug caps with sealing assemblies. The coil-packs are held with two 10mm bolts each and are difficult to get to. Use universal-joint sockets and an extension.
Apr 06, 2009 | 2004 Kia Optima
Ngk Lfr5A 11 Spark Plug Logo
300 people viewed this question
Top Ngk Boating Experts
Steve
Steve
 steve
steve
Phil Walker
Phil Walker
Are you a Ngk Boating Expert? Answer questions, earn points and help others
