Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
My eclipse elliptical will not turn on. I just replace the AC adapter with a new one from the factory and it doesn't work.
2 Suggested Answers
SOURCE: where can i find an ac adapter for eclipse 1100 hra elliptical
http://www.ebay.com/itm/like/201135397361?lpid=82&chn=ps
Posted on Jan 09, 2015
My Proform 6.0 ZE elliptical is draining new batteries within hours and humming. It makes LOUD popping and static sounds when using the AC plug in.
DEAR
AT FIRST YOU COUNT YOUR BAT AND MULTIPLY 1.5 THEN YOU USE A ADAPTER AC TO DC WITH SAME VOLTAGE LIKE 6 V OR 9V DC
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 21, 2017 | Proform Pro Form 6.0 ZE Elliptical
My hp netbook wont turn on, what shoud i do?..
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Nov 05, 2012 | HP Mini 210-1030NR Netbook
Acer travelmate 8472 not switching on
Take out the battery and hook up the AC Adapter to it. Hook up the adapter to a working outlet. If the laptop still doesn't turn on then try another working AC Adapter. If the laptop doesn't turn on at this point then that means the motheboard is bad and would need to be replaced.
Feb 05, 2012 | Acer Computers & Internet
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
The program monitor on my eclipse 1100hr/a elliptical trainer does not work, what may be the problem?
After about 4 years, one day my monitor just wouldn't turn on. After making sure the batteries were new, I took out the four screws on the back of the monitor and made sure the two wire connections were tight. They were, so I called Fitness Quest customer service (1-800-321-9236) from their website (fitnessquest.com). For about $120 including shipping they sent me a new monitor. It took me about a minute to undo the old, plug in the new, and now it works great! The flat connection with the multi-colored wires requires a gentle squeeze with a pliers on the sides while you glently wiggle and pull it apart. Look at the new connector to see how it should come apart. Good luck!
Jan 03, 2010 | Fitness Quest Eclipse 1100 Hr/A Elliptical
My eclipse 1100 hour monitor is not working (already replaced batteries and still nothing)
Check it out. If you machine monitor shows and e-1 when trying to turn on. Take out the batteries and unscrew the four screws on the bottom of the monitor unplug it from the elliptical. Put the batteries back in turn on monitor the plug it back to the elliptical while still on and screw back in places. It worked for me hope it works for you too.
Brian Pickens
Long beach ca
Oct 15, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Monitor diplays E1 and won't stop beeping
Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
Eclipse Recall Instructions and Form (PDF)
Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
105 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
ray gallant
Dave Callender
Dave Callender
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
