Question about GE Refrigerators
Fresh food side is running too cold (Liquids freezing), regardless of temperature control settings. G E Model GSS20IETE
  • 613 Answers
There is a vent opening on the bottom or in the back. Make sure it is not one sided or blocked with items since the temperature settings make no difference. This is all it can be.
Posted on Jan 02, 2011
Refrigerator is freezing food and liquids with the controls set to their lowest setting.
This could be caused by a defective=> WR60X10052 Damper Control Assembly or could be caused by a defective fresh food thermister=> WR55X10027 Thermistor or WR55X10027 Thermistor. You will need to run the diagnostics found in the GSS25LGMA Service Manual I am here should you need me, Thanks John Tripp Appliance 911
Mar 19, 2014 | GE Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Too cold
If the unit seems to be running non stop, you may have a bad cold temp control. If you have ice cream in freezer, it will likely be rock hard, that you need a chisel to scoop. if your ice cream is ok, its likely not the temp control. On your GE, in the fresh food section, do you have a canopy on the ceiling of fridge, and likely covers the whole top back portion of your fridge? If you do, there is a damper door inside, that breaks off its hinge, and stays wide open, allowing cold air from freezer to constantly be pulled into fridge, freezing food. If you do have this canopy, it will need to be replaced, as you cannot reattach the damper to its hinge.
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
Freezer is coldbut the fresh food side is warm
there is probably something wrong with the defrost if you dont take the bak off and defrost all of the ice off they will freeze back up in no time
Apr 24, 2009 | Frigidaire 22.6 cu. ft. Side-By-Side...
Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Dec 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
