Question about IMSI Micro Cookbook Suite 5.5 Full Version for PC
How do I install my MicroCookbook 5.0 to my new Windows 7? I still have my original disc from when I bought my first Computer and the disc came with it . It has 3 other applications on the same disc.
Reset windows 7 password hp
You may try the below steps to reset or recover the windows login password:
1) Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free.
2) After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
3) Click on the Repair your computer link.
Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
4) Wait while your Windows 7 installation is located on your computer.
5) Once your installation is found, take note of the drive letter found in the Locationcolumn. Most Windows 7 installations will show D: but yours may be different.
Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
Hope this helps..
Feb 18, 2015 | HP Computers & Internet
Tip
Bypass Windows 7 Password - 3 Workable Options Meet Your Needs!
Whether you've just bought a new Windows 7 PC or upgraded to Windows 7, it's necessary for you to set a strong password to protect your computer data and stop unauthorized users. Meanwhile, some precautionary measures should also be taken in case that you may need to bypass Windows 7 password as is forgotten or lost.
However, not all users know and remember to take these preventive measures. If you are a green hand with computer, there are still 3 common options for Windows 7 password recovery.
Option 1: Bypass Windows 7 Password with Fingerprint Logon
As this method, Windows 7 provides native support for fingerprint biometric devices through Windows Biometric Framework (WBF). Of course, the premise is that your laptop or computer has a biometric sensor.
Option 2: Bypass Windows 7 Password with An Installation Disc
As is known, the System Recovery Options, provided by computer manufacturer, offers Windows installation disc or the recovery options which can help you reset Windows 7 password. Now, create an installation disc by yourself.
Step 1. Enter system repair disc into the search box in the Start menu, and then click Create a system repair disc.
Step 2. Insert a blank CD/DVD into the optical drive and click Create disc.
Step 3: The System Recovery Options are displayed, and then reset Windows7 password.
Option 3: Bypass Windows 7 Password with Reliable Password Recovery Toolkit
There are various Windows password recovery tools. Take two kinds of widespread toolkit for your reference.
Ophcrack
Ophcrack is one of the most popular free Windows password cracker based on rainbow tables. It can help you reset Windows password less than 14 characters. Once you forgot Windows 7 password, it is a good choice to download the version compatible with Window 7. However, many Windows users failed to recover Windows password as its large ISO file which is more than 496MB.
Windows Password Unlocker
Windows Password Unlocker is a highly appreciated Windows password recovery toolkit, especially designed for novice or new beginners . With this tool, you can get instant access to locked computer without the old password and computer skills. Prepare a bootale CD/DVD or USB flash drive and follow these 4 steps with less than 5 minutes.
Step 1: Download Windows Password Unlocker Professional and install it in any available computer
Step 2: Burn a bootable CD/DVD or USB flash drive
Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
Step 4: Bypass Windows 7 password sucessfully
By the way, we have collected some tips to avoid or lessen Windows 7 password lost trouble.
Some Tips For Preventing Windows 7 Password Lost
Tip 1. Set a password hint when creating the Windows 7 password, which will remind you of the forgotten password..
Tip 2. Create a password reset disk for your Windows 7 account, which you've never worried about if you forgot Windows 7 password. Write your password down and place it in a safe place.
Tip 3. Create a system repair disk. You'll be able to access to the recovery options and bypass Windows 7 password with ease.
With these preventive measures, it's a piece of cake for Windows 7 password recovery and regain access to your compute even if you forgot the password.
on Jan 11, 2011 | Computers & Internet
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
Forgot password
  1. Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
    Tip: See How to Boot From a CD, DVD, or BD Disc or How to Boot From a USB Device if you've never booted from portable media before or if you're having trouble doing so.
    Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free. See How to Create a Windows 7 System Repair Disc for a tutorial.
  2. After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
  3. Click on the Repair your computer link.
  4. Wait while your Windows 7 installation is located on your computer.
  5. Once your installation is found, take note of the drive letter found in the Location column. Most Windows 7 installations will show D: but yours may be different.
  6. Select Windows 7 from the Operating System list and then click the Next button.
  7. From System Recovery Options, choose Command Prompt.
  8. With Command Prompt now open, execute the following two commands, in this order:
    copy d:\windows\system32\utilman.exe d:\ copy d:\windows\system32\cmd.exe d:\windows\system32\utilman.exe To the Overwrite question after executing the second command, answer with Yes.
    Important: If the drive that Windows 7 is installed on in your computer is not D: (Step 5), be sure to change all instances of d: in the commands above with the correct drive letter.
  9. Remove the disc or flash drive and then restart your computer.
    You can close the Command Prompt window and click Restart but it's also okay in this situation to restart using your computer's restart button.
  10. Once the Windows 7 logon screen appears, locate the little icon on the bottom-left of the screen that looks like a pie with a square around it and then click it!
    Tip: If your normal Windows 7 logon screen did not show up, check to see that you removed the disc or flash drive you inserted in Step 1. Your computer may continue to boot from this device instead of your hard drive if you don't remove it.
  11. Now that Command Prompt is open, execute the net user command as shown, replacingmyusername with whatever your user name is and mypassword with whatever new password you'd like to use:
    net user myusername mypassword So, for example, I would do something like this:
    net user Tim 1lov3blueberrie$ Tip: If your username has spaces, put double quotes around it when executing net user, as in net user "Tim Fisher" 1lov3blueberrie$.
  12. Close the Command Prompt window.
  13. Login with your new password!
  14. Create a Windows 7 Password Reset Disk! This is the Microsoft-approved, proactive step you should have done a long time ago. All you need is a blank flash drive or floppy disk and you'll never need to worry about forgetting your Windows 7 password again.
  15. While not required, it would probably be wise to undo the hack that makes this work. If you don't, you won't have access to accessibiily features from the Windows 7 login screen.
    To reverse the changes you've made, repeat Steps 1 through 7 above. When you have access to Command Prompt again, execute the following:
    copy d:\utilman.exe d:\windows\system32\utilman.exe Confirm the overwrite and then restart your computer.
    Important: Undoing this hack will have no impact on your new password. Whatever password you set in Step 11 is still valid.
Oct 14, 2013 | Computers & Internet
I use MS Money 2001. I bought a new PC and is changing from MS Windows XP Pro to Windows 7 Pro. I would like my ms money 2001 to continue working on new PC but I can't find the original disc to copy on...
Hi pjhmulder
Assuming MS Money 2001 and 2003 are compatible with W 7 , you could install MS Money 2003 on the new computer and copy the files from MS Money 2001 on the old computer to MS Money 2003 on the new computer . Make sure you don't erase the MS Money 2001 files before transfer has successfully been executed .
Best regards ,
fanaudi .
Aug 12, 2011 | Microsoft Computers & Internet
I just bought a new computer, is comes with windows 7, it will not install my printer software, what should I do?
It is most likely due to the original software not being compatible with Windows 7. Go to the printer's manufacturer's website and look for "download drivers" or something similar. Download the drivers for Windows 7 (make sure you select 32 or 64 bit according to your computer) and install these drivers. If the printer is very old (4-5 or more years old), there may not be drivers available.
Dec 14, 2010 | Office Equipment & Supplies
I recently bought a new computer using windows 7 now my veo stingray webcam does not work is there a driver i can download to fix this problem.
Not sure but you can use your original install disc and if that doesn't owrk you can got to cnet downloads and see if there is a new driver download there for the device that is compatible with windows 7.
Hope my advice helps and thanks for voting/rating, etc...
Stormi
Nov 15, 2010 | Veo Stingray
I use MGI photosuite and love it. I just bought a
Windows 7 and 8 much the same (32 and 64 bit) you may missing files for Internet Explorer.
Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD has
I.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway.
I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running.
Jun 25, 2010 | MGI Software PhotoSuite SE V4.0
I bought a new hp computer with Windows 7 os. I
Your allinone is not compatible with new OS as you have already figures out. Contact the Company..hp and see if they have an updated disc for MS7.....
If you can get your hands on a new disc for the HP AIO's they are all similar...and you can try reinstalling using it.
Go to Walmart...buy new HP AIO.....install disc..connect old AIO....take back new one with disc.....problen solved. walmart will accept all returns.
Dec 29, 2009 | HP PSC 2350 All-In-One InkJet Printer
IMSI Micro Cookbook Suite 5.5 Full Version for PC Logo
178 people viewed this question
Top IMSI Computers & Internet Experts
Lesley Cameron
Lesley Cameron
Dan Shibata
Dan Shibata
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
