Question about Whirlpool Dryers
Although my tumble dryer is heating up, it isn't extracting the moisture even though I have cleared the fluff.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you may have a clog in the vent line, in back of the dryer, and from the wall to the outside of the house.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
The door shuts and the screen says close fluff door even though it is shut and clicked in
switch is damaged happens a lot you will need to replace the switch.
Mar 30, 2015 | Miele T8005 Tumble Dryer
Tumble Dryer intermittent squeal, then stopped heating, now black soot underneath
Dryers are susceptible to lint fires in their exhaust vents. You should be checking the exhaust vent at least once a year and clearing any blockages. If the exhaust vent becomes blocked, the dryer will heat up significantly and the lint could catch fire if there is enough heat build-up. If you don't clear the exhaust this will almost certainly happen.
Fire needs a source of heat (red hot heating elements), fuel (lint) and oxygen (the exhaust fan blows air at the blockage).
You should be able to replace the burned out heating element if you are comfortable doing the wiring. You can pay a repairman if you like but wiring is only so much common sense. Photograph the wiring before you start for a post repair check. Replace the element and any burned wires. Make sure the connections are tight and that there are no loose wires. Only the ground wire should be bare.
A Dryer uses 220V AC (in North America) like a stove and some water heaters. This is enough voltage to kill even hardy souls who laugh at 110V (usually enough to kill but not guaranteed to).
When you check the vent, check that it has some sort of safety rating. Not all flexible vent is fire-resistant. This scared me when I saw it on YouTube or somewhere.
Why did your smoke detector not go off when the element melted?Good thing to know if your utility charges less for power in off-peak hours. My mother often runs hers at night when the rate is very low.
My dryer runs from sunrise to sunset but we use an electric one in the winter months.
Sep 20, 2012 | Indesit IS70C Electric Dryer
Dryer will not heat; vent is clear, moisture sensor is clean, turned breaker off/on
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 22, 2011 | Bosch WTMC632SUS Electric Dryer
Winndscreen does not clear unless have air conditioner on
Blowing air across the windscreen does not necessarily clear away condensate from the inside. Water vapor condenses on any cool surface, and humid air blowing across a cool windscreen will result in more condensate on the windscreen. Often the air that blows across the windscreen is just humid AND heated, and doesn't solve the problem.
The air conditioner system performs two functions. Not only does it cool the air, it also extracts moisture, resulting in dryer air. Once the dried air is re-heated in the defroster system, it should allow the moisture on the windscreen to evaporate.
In other words, it sounds as though the defroster system is functioning properly.
Feb 06, 2011 | 1998 Volvo S70
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
I don't have any heat from my hotpoint aquarius ctd40G Tumble Dryer. I have cleared all the fluff from the condenser unit and unplugged the mains and tryed it all again but we still do not have any heat...
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
I have to use my indesit condensing tumble dryer about 3 times to get 1 load to dry
Hi.
Make sure the fluff filter and water tray are clean and empty.
Also make sure it is on High heat setting, and set the correct time.
Nov 28, 2008 | Dryers
Dryer not heating
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 02, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
Dryers Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
