Question about Cobra 29 LTD CB Radio
Cobra 29 ltd classic someone messed with all the lil screw ins and gave it to me, problem its having is , you hear some background white noise, try to key up but no TX? the dead key drops altho talkback is loud and clear
    Novelist:
  • Cobra Expert
  • 500 Answers
That will need an oscilloscope to get it back right. we can fix for you. wouldn't cost much if all it is just out of alignment and nothing is broken...
Posted on Jan 03, 2011
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
Cant adjust swr on cobra 29 with swing kit
make sure you have no noise in the background at all the be my guest. you may have to put a cloth over the mic speaker to keep the noise level down but you can do it.
Jan 28, 2014 | Cobra 29 LTD CB Radio
What is a voic box on a cobra 29 ltd? What is a good antt combo four a 29 ltd?
Cobra's LTD 29 model Citizen's Band radio features the full 40 channels allowed and a heavy-duty microphone. The radio provides 4 watts of AM radio frequency output with a switchable automatic noise limiter and noise blanker. Other features include Cobra's Delta-Tune function. Making a Cobra LTD 29 hear and receive better involves making changes to the radio's settings, including the settings specific to this brand.
M/F Turn the switch labeled "NB/ANL, ANL, OFF" to the "ANL" position and try the transmission again if noise is affecting reception. "ANL" is an automatic noise limiter function and reduces noise caused by the vehicle's electrical systems and electronics.
M/F Switch to "NB/ANL" to activate the noise blanker, which may also reduce noise if you continue to have problems. It's an RF noise filtration function and will help with ignition noise.
M/F Adjust the "RF Gain" knob by turning it clockwise to increase gain in weak signal areas if you have problems hearing radio traffic.
M/F Set the "Delta-Tune" function to capture a more listenable signal and get rid of adjacent channel noise. Rotate the knob labeled "Deltatune" to the center position for best tuning. Try micro-adjustments to the left or right as well.
M/F Turn the volume up if you still can't hear and as with any CB radio, adjust the squelch if the radio is noisy when there's no traffic. Turn the knob labeled "Squelch" all the way to the left to receive all signals, including noise and turn the control clockwise until the background noise stops. You will be able to hear the strongest transmissions without having to listen to weak signals and noise.
The service manual can be found here
Jan 23, 2013 | Lands Phones
My cb cobra 29 ltd problem is channel 1 is ok but channel 2 not receive
Did you have someone get on channel 2 to see??? Maybe channel 2 was quiet and channel one had better receive or noise.. You never know until you check it with another radio. That is NOT a common issue at all on those radios. Better off doing that test.
"WILDCAT" IN LAURELVILLE OHIO
35 YEARS OF CB FUN!!!
Dec 28, 2010 | Cobra 29 LTD CB Radio
I just bought a cobra 29 ltd, i hooked it up and calibrated it the way the manual said but when i turn it on and turn my squelch all the way to the left i barley hear it at all, and i have the volume all...
there may be a very low noise level. If the noise level is low you will hear almost nothing. You need to go on ch 19 and drive near a major interstate.
Key up and say, "Break one nine for a radio check" and a trucker will come back and tell you its working. If you hear him okay, then your radio is working fine.
Some days, background noise is heavier and lighter then others.
Oct 18, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd classic side mic
First off I dont believe anyone to peek and tune but anyways. Make sure your mike is for the radio wiring. Next the guy that rigged it up might have gave you all the channels do all your knobs work??? usually you can tall as you get someone to talk with you a few blocks away and start, start turning and flipping switches till you can hear him most likely the guy that did the work on it messed it up. for a filter use a farite choke from radioshack on the mike wire.
Mar 17, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD Classic Operations Manual
For the operation manual, go to cobraelec.com or:
http://cobra.com/downloads/manuals/29LTDCLA.PDF
Thanks!
Dodgem
http://dodgem250.angelfire.com
May 05, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
94 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
