Question about Frigidaire Dryers
Will not start when hot buzzing noise
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
My 2000 yukon denali makes a buzzing noise on drivers side
yes sorry to say with out hearing the sound my self it could be 6 one way half dozen the other but try a flush and see if that stops the buzz and over heating should be around 100 to flush or it also now could be low on atf try a top off first ( be sure not to over fill)
Jun 27, 2012 | 2000 GMC Yukon XL
Hot water tap creates an annoying noise in the mh. The noise is coming from the Atwood hot water heater. (2007 Coachmen Mirada).
Like a buzzing noise? Check valve where water lines connect at back will make a buzzing noise, if you only hear it when running hot water and not when running cold. Remove and replace it after shutting water off, and draining tank down. Be sure to shut off any hydro to electric element prior to draining.You can buy a replacement check valve, or just put a short 1/2" pipe nipple in there instead and reconnect your line, and refill it. noise should be gone .
Jun 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
Hot Point Dryer does not come on but you can hear the noise by the start knob like a low buzz
Feel the outer cover at rear of the dryer at the bottom,if it starts to feel warm then the heater is working, the buzzing noise could be the motor trying to start, or noise from the relay, if the heater does not come on then could be timer faulty or faulty start relay. It is a a process of elmination.
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Buzzing noise! when the
sounds like you have a problem with the water solenoids (the electronic controlled water valves) the buzzing is an indication that it is trying to open or close and unable to do so. an electric current creates a magnetic field pulling a spring loaded valve sealed inside a tube allowing water to pass. it starts buzzing when it can't pull the valve all the way and just vibrates.
May 03, 2008 | Westinghouse WWS833ES Super Capacity Top...
Dryers Logo
51 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
