Cars & Trucks Logo
Anonymous Posted on Jan 02, 2011
Need instructions for power steering pump replacement on a 1992 pontiac trans sport. FAST PLEASE!!! has a 3.8L engine with a/c. thankyou for your help!
Archaeology
Level 3:
President:
  • Master 662 Answers
  • Posted on Jan 02, 2011
Archaeology
Master
Level 3:
President:
Answers
662
Questions
8
Helped
495842
Points
2068
-- from the 1990-1999 Lumina / Silhouette / TranSport Repair manual ---
1992 Pontiac TransPort Power Steering Pump REMOVAL AND INSTALLATION
  1. Disconnect the negative battery cable.
  2. Disconnect and cap the power steering pump hoses.
  3. Remove the accessory drive belt.
  4. Remove the power steering pump pulley using a suitable puller tool.
  5. Remove the pump mounting bolts and remove the pump from the vehicle.
See Figures 1, 2 and 3
need instructions for power steering - 0900c152801dbcf7.jpg enlarge_icon.need instructions for power steering - enlarge_tooltip.gif><span><img loading=
Fig. Fig. 1: On some vehicles, you must use a puller to remove the pneed instructions for power steering - 0900c152801dbcf8.jpgulley
Fig. Fig. 2: Power steering pump mounting-early model vehicle shown
Fig. Fig. 3: Power steering pump mounting-late model vehicle shown
  1. Installation is the reverse of the removal procedure. Tighten the pump mounting bolts to 18 ft. lbs. (25 Nm).
  2. Bleed the power steering system to remove trapped air. Air in the system could cause noise and or damage to the pump.
BLEEDING
This procedure requires the help of an assistant.
  1. With the engine OFF, the wheels off the ground and turned all the way to the left, fill the fluid reservoir to the FULL COLD mark on the fluid level indicator.
  2. With an assistant checking the fluid level and condition, bleed the system by turning the wheels from side to side without hitting the stops. You should repeat this at least 20 times, making sure to need instructions for power steering - 0900c152801dbcfa.jpgel at the FULL COLD mark.
Fluid with air in it has a light tan appearance. This air must be eliminated from the fluid before normal steering action can be obtained.
See Figure 4
need instructions for power steering - enlarge_tooltip.gifww.autozone.com/autozone/repairinfo/repairguide/repaiguideOverlay.jsp?src=http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/1d/bc/fa/large/0900c152801dbcfa.&imageType=gif&imageName=Fig.%204:%20Power%20steering%20bleeding%20procedure">enlarge_icon.gifenlarge_tooltip.gif
Fig. Fig. 4: Power steering bleeding procedure
  1. Start the engine, and while it is idling, recheck the fluid level and add as necessary to reach the FULneed instructions for power steering - 0900c152801dbcfb.jpg
  2. Return the wheels to the center position. Lower the front wheels to the ground and continue running the engine for 2 or 3 minutes.
  3. Road test the vehicle to make sure the steering functions properly and is free of noises.need instructions for power steering - enlarge_icon.gif
See Figuneed instructions for power steering - enlarge_tooltip.gif />
0900c152801dbcfb.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 5: Torque specificatio
  • Archaeology
    Archaeology Jan 02, 2011
    Lets try again:
    --- from 1990-99 Lumina / Silhouette / TransPort Repair Guide ---
    http://repairguide.autozone.com/znetrgs/..." rel="width:950,height:660" id="repair-multibox" class="mb-image2-overlay image-overlay" title="Enlarge">
    Fig. Fig. 1: On some vehicles, you must use a puller to remove the power steering pump pulley
    BLEEDING
        stops. You should repeat this at least 20 times, making sure to keep the
        fluid level at the FULL COLD mark.
    See Figure 4
        Start the engine, and while it is idling, recheck the fluid level and add as necessary to reach the FULL COLD mark.
    See Figure 5
    Fig. Fig. 5: Torque specifications
  • Archaeology
    Oops - you can access this repair guide (free) by registering at www.autozone.com.
How to i remove power steering pump
I suspect the pump is not leaking but a hose that goes to the pump. Either way this is a difficult job. Almost everything that is on the pump side of the engine must be removed first to get access to the pump and it's hoses. Good Luck.
1helpful
Turn signal flasher on 1992 pontiac trans sport
The flasher is attached by a clip to the interior panel on the lower right side of your steering wheel. I hope that answers you question. Feedback and ratings are appreciated as well.
My steering stopped working but as long as I wasn't turning right or left the van ran well but then it starting having a knocking sound and now it won't turn over. It isn't out of oil. Help!
Check your serpentine belt in the engine compartment. It could have broke which would explain the power steering pump failing and now the battery could be dead since it was not being charged. If it is the belt, once it is replaced you should only need to jump the battery.
Power steering doesn't work and the bottom pulley froze, can i replace the pulley or is it something worse?
It's something worse. the Pulleys don't freeze. the internal mechanisms freeze. you need a new Power Steering Pump....Sorry
1helpful
2answers
Need instructions for replacing rack and pinion in my 1993 pontiac trans sport
disconnect the tie rod ends on bothe spindles.next take the bott out of the steering saft going into the rack. next disconect the power steering lines (take a piece of masking tape and perminant marker and leave a note wich line goes were.) next just unbolt tghe rack and slip it out of the wheel well.
3helpful
My 1992 Trans Sport starts then shuts off right away
fuel problem somewhere along the line¿¿¿ but where ,i would remove the tank sender unit and check the pump and pump flexible connection first
98 Pont Trans Sport
Hi the fuel pump is in the fuel tank
Engine won't turn over
It was a conrol module that needed to be replaced.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
