Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I cannot get the three point hitch on my tractor to come down. The internal and external controls will not work and even heat will not loosen it up
  • 3 Answers
HAVE YOU TRIED ADJUSTING THE DOWN SPEED? ON MY
1967 JD 2020 THE ADJUSTING SCREW IS LOCATED AT THE
CENTER OF THE TRANSMISSION CASE BELOW THE FRONT EDGE OF THE SEAT. LOOSEN THE LOCK NUT AND
ADJUST THE SCREW TO OBTAIN THE DESIRED SPEED.
Posted on Jan 02, 2011
Http://www.cnn.com
Posted on Mar 02, 2011
How to remove/replace Kubota b7100 three point hitch hydraulic control lever
Try you tube, type "How to remove/replace Kubota b7100 three point hitch hydraulic control lever." there are videos.
Aug 20, 2016 | Kubota Garden
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
Deere 5525 control stick is difficult to pull back
Are you talking about the three point hitch lever? Does it have a cable going to the three point hitch spool valve? If so, try spraying penitrating oil in the cable at both ends.
Jan 02, 2015 | Garden
How to adjust mahindra 5005 three point hitch down pressure?
1 Draft sensing lever in wrong position
Move lever to "light" position.
2 Rate-of-drop too slow
Adjust rate-of-drop valve.
3 Center link on upper front hole
Move center link to lower hole.
4 Draft control out of adjustment
Refer to service manual for adjustment procedure.
5 Internal mechanical interference with load control linkage
Refer to service manual to find interference, or possibly linkage coming apart.
6 Load control shaft or tube broken or bent
Replace load control shaft or tube. Refer to service manual.
7 Load sensing pin malfunctioning, or bad connections - only applies to newer tractors
Replace load sensing pin, repair faulty connections. Refer to service manual.
Aug 13, 2014 | Garden
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
I just got 7210 john deere tractor i cannot get the three point hitch to go down what can i do?
We have had problems with light rust on the cylinder walls. Honed the rust out and lift worked great
Feb 05, 2012 | John Deere 7200,7210 All W/o Cab Tractor...
John Deere 4410 three point hitch will not raise. All linkage is intact, no I believe that there may not be hydraulic pressure, although the front loader does work. Recently changed hydraulic oil and...
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Sep 25, 2009 | John Deere 3-point Hitch Kit A,b,g,50,60...
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
3 point hitch wont lower
Some of these tractors have a knob under the seat that locks the three point up so it cannot be lowered by accident. Check for this knob and open it.
Mar 27, 2009 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
405 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
