Question about Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA)
The keyboard on our hp does not work. Appears there is no power (power light stays on about 1 sec when we first connect to the tower. plugged in another keyboard with the same results. Is there a driver or a internal board that has gone bad? Thanks, KT
  • 97 Answers
If the machine otherwise boots fine except for the keyboard. Your problem could be in the keyboard port. Try using a usb keyboard to test it.
Posted on Jan 02, 2011
On a hp pavilion a 1 1 10n I did somehing to cause
computer keyboards can have faults in several ways, but the most likely is liquids being spilt on them, causing them to do odd things or to just stop working completely.
There's loads of people having problems with this series of keyboards. With some keyboards the speed is wrong for them being checked (USB versions) and you can easily type faster than the keyboard controller can respond so it just goes nuts :-(
Notably, lots of laptops have a problem handling fast typing and tend to throw the cursor around or mis and add random letters.
Try a different keyboard just in case. Check its wire and connections for breaks/damage. Plug it into another USB port if possible some towers give lower power/resources to some USB ports - especially ones on the front of tower cases.
Also, some odd BIOS's allow you change the typing rate/speed (usually quite old ones though). If that value doesn't match your keyboard enough you can have problems.
Aug 06, 2013 | HP D8597A Keyboard
My system power supply gone dead and i replaced the same power supply but from that it shows keyboard error 304 and i have to press f 1 to start computer. please tell me how i resolve this problem.?...
simple fix.Unplug tower; hold power button for 10 secs for discharge; take off cover; uninstall your CMOS battery(the silver watch battery the size of a nickel), and plug unit back in; power on for 15 secs. This will set HP back to factory settings default. Cut off; re-install CMOS battery, and plug back up. this should fix problems. hope this helps...
Aug 05, 2011 | HP Compaq d530 SFF PC Desktop
I have an HP pavilion M9040N tower that has power (green Light on) but shuts of in 1-2 seconds after turning on the power button( blue light) on top. Tried removing various components with no change...
As you have already troubleshooted a lot ... but i want you to check by replacing power-supply (SMPS) in most of the cases such problem are created by faulty smps. No doubt it's getting on but SMPS can create such problem. So check with that if haven't check for it.
Apr 23, 2011 | HP Pavilion M9040N Elite Desktop PC
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Thanks
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
Computer worked perfect. Internet went out. Unhooked everything and now the tower power light just continuously revolves and will not start
Do this way
1.Discoonect all the cables from the tower
2.Press and hold the power buuton for 30 secs.
4.Now connect only 4 cables i.e.monitor,power,keyboard,mouse
5.turn on the pc
Sep 06, 2009 | Sony VAIO VGC-RB42G PC Desktop
ViewSonic VX910 monitor appears to have power supply issue. The power light comes on for less than 1/2 sec, then goes off for about 1 sec, then just flashes green. If you play with the switch and the A/C...
try running the self test on the monitor
Self Test:
turn off the system disconnect the data cable from the tower and connect only the power cable to the monitor and trun on the monitor if you see colour full bars then the monitor is ok then try to go BIOS and see if the monitor is working
Jul 01, 2009 | ViewSonic VX910 19" LCD Monitor
WONT BOOT BLACK SCREEN
this is a easy one plug up your unit take out ur battery for 30 sec while holding do the power button hit the power button once again and it should come on and if it dont the great things is there a recall on those pc call hp they will send u a new pc free of charge
May 22, 2009 | HP Pavilion zd8000 Notebook
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Hp pavillion desktop will not power up. Blinking green light at power supply
Step 1 : Turn off the system by pressing the power button for 5 - 10 sec until the power LED is off. Removed all cables including the power cable (Exclude monitor cable and KeyBoard/Mouse).
Step 2 : Press power button for 5-10 sec again to drain fela power.
Step 3 : Reconnect the power cable at the back of the tower/computer and power on the system.
**If the same problem exists, Call HP tech Support (800-474-6836) because there is a high possibility that you have a bad Motherboard or Power Supply on the system.
Oct 28, 2008 | HP Computers & Internet
Compaq Presario SR1810NX Sempron 3200+ 1.8 GHz Desktop PC ( Monitor Sold Separatley) (ER912AA) Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
