Question about Porter Cable Garden
I have a Porter Cable cordless drill. It is only 1 year old, I was just using it and all of the sudden it just quit working. I was wondering if there is a warranty to cover this issue. The date Stamped on the bottom of the drill is 2009 21 -BM. I need this drill for work so please respond promptly.
  • 2,428 Answers
It hnk i have the same gun. i have know idia where you found the modal # mine is an 18 volt nica battery and iv'e had it for a year and the 7 inch saw i also use them for work and like them and had no problems. But i found the manual that came with it just no modal or serial # eighter for that matter. I says there is a 1 year free serivice for worn parts under normal use. that would deturmin. Then i started looking closer and found a 3 year warranty for faulty meterals or workmanship and thats also free. Give me a fax # and i'll send it to you or www.portercable.com and they have an # 888 848 5175 truthfuly the manual is not vary helpfuf dosn't cover much but if you need the warranty in wrighting i can send it to you
Posted on Jan 02, 2011
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
I am having problems with my 18v porter cable cordless drill. I have had it for two year and have rarely used it. Only used one battery. Now I am unable to charge either of the batteries. They are lithium....
Do not try to repait the battery. There is a possibility you could fix it but don't try it. Acid is not friendly on humans body.
go out and buy new batteries for it. I would suggest you buy the type of battery it came with.
One more thing; Make sure you remove the battery and store it in a normal temperature area anytime it is not in use.
Please rate if this helped you.
Apr 17, 2011 | Porter Cable-Cable PCL180DK-2 18-Volt...
I WOULD LIKE TO BUY A MODEL # 830 CORDLESS DRILL KIT
Hello, not sure of where you are located so here's a link to the main Porter Cable "contact page", as well as a "locate dealer" page.
http://www.portercable.com/WhereToBuy/WhereToBuy.aspx
http://www.portercable.com/AboutUs/ContactUs.aspx
If this helps please rate a four-thumbs up. Thank You.
Mar 25, 2011 | Porter Cable 830 96v Cordless Drill Driver
Porter cable hammer drill 987 suddenly stopped running.
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Mar 04, 2011 | Porter Cable 987 19.2 Volt Grip - To - Fit...
Need serpentine belt routing diagram for 99 cadillac deville. i am trying to replace the belt just replaced ac compressor thank you
There is always a small diagram under the hood somewhere in my experience. It is usually on the radiator support, hood, or strut tower.
Nov 20, 2009 | Porter Cable Factory-Reconditioned...
The electronic brake does not work
should be the switch, give me the model number and I will find a part number for you.
Oct 14, 2009 | Porter Cable 12v 3/8" Cordless...
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Sep 27, 2008 | Porter Cable Cable 19.2 Volt Grip - To -...
Garden Logo
79 people viewed this question
Top Porter Cable Garden Experts
andy just round the...
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
