When I press turn on button on my pc tower, green light does not turn on, so windows does not load, I have to turn pcu manually off and on several times to get windows to load. Thank You
  • 97 Answers
Well,
It could be something as simple as the power button on the front of the unit, to the power supply inside the unit. If you are feeling brave, you can take off the front panel and try to engage the power switch manually
Posted on Jan 02, 2011
I have an old Dell DE051 tower and I have it hooked up to my TV via VGA cable. When I turn on the tower, the dell loading screen appears and then moves onto the Windows XP loading screen. The problem...
Could be the pixal setting on the tower is too high for the TV? Can you change the video card settings to the TV Pixal rating? You could have a bad video card. Good luck.
May 01, 2014 | Computers & Internet
No sign of life from the display half but the bottom reads life.
If you have already checked the connections from the screen to the PC, check that you have a power light on the screen. (Green or Amber). If no light, check power to screen. If it is amber, then the screen is not getting a signal from the PC - recheck connections. I would suggest you try and connect the pc to a different monitor to check whether it is the screen or the PC.
If it is the same on another Monitor or if the power button is green on the screen, then the pc is not sending information properly. Turn the pc off manually by holding the power button on the bottom half for about 10 seconds. All lights should go off from it. Now turn it back on again and see what happens.
If you see loading windows and then goes black, do the following:
Turn off the pc (bottom half). Turn back on and as soon as you pressed the button to turn on, start tapping the F8 key until you come to "Windows Advanced options" screen. use the arrow keys and go to Enable VGA mode. Press the return key twice. If it loads to windows, then fine. If not, then you may have a problem with the display adapter.
Hope that helps
Nov 11, 2010 | Computers & Internet
Veriton 7200D ACER - I went to turn on my computer today and it wont turn on. On the front of the tower there is a green light flashing intermittently. Looking at the back of the machine I see that the...
Press and HOLD the ON/OFF button for TEN seconds, until the computer turns itself off.
Then, press the ON/OFF button as per normal, and it should start.
Sep 27, 2010 | Acer Veriton 7200D PC Desktop
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
HAVE REPLACED BOTH THE PCU & THE TONER IN MY LEXMARK E250DN PRINTER BUT STILL KEEP GETTING ERROR MSG TO REPLACE PCU IT HAS REACHED THE END OF IT'S LIFE
you need to reset the counter. the new pcu should have come with instructions to do this. 1. Turn off the printer. 2. Open the front cover. 3. Press and hold the Continue button (Big silver button with Diamond shape symbol) and turn the printer on. 4. Hold the button down until the last light (error light) is on solid, release the button and close the front cover. 5. When the cover is closed, all the top 3 lights should be on solid. 6. Press the cancel button (triangle symbol) 4 times very slowly until you see the toner low light (second light from top) on solid. 7. Press the continue button and wait until you see the light sequence. 8. Press the cancel button and wait until you see the light sequence. 9. Finally power off the printer and power it back on to exit the configuration mode.
Jun 16, 2009 | Lexmark E250dn Laser Printer
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Jun 12, 2007 | OKI B8300 Laser Printer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
