Question about Refrigerators
I HAVE A HOTPOINT REFRIGERATOR MODEL CTX14CYXKLAD. MY REFRIGERATOR IS BUILDING UP WITH WATER UNDER THE VEGTABLE/FRUIT DRAWS....HELP
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Water build up in the
Water build up under the fresh food drawers is usually associated with an air intrusion from the exterior. Warm air intruding into the fresh food compartment creates excess condensation, which eventually accumulates on the bottom.
Some causes are:
1. Internal obstruction, not allowing door(s) to close tightly enough.
2. Deteriorated door seal, (torn, pinched, deformed, misaligned,).
3. Light not turning off when door closed,(faulty door switch, misaligned door, loose hinges allowing door to drop).
Make sure all drawer have nothing obstructing their closure, and door shelves have nothing extending beyond the support bars.
Other less obvious causes may be creating this issue also and are not normally addressable by the novice servicer.
Hope this helps find the cause.
Posted on May 25, 2008
NorseXNW
  • 8 Answers
SOURCE: A puddle of water is laying under vegtable and fruit drawers
Clean out the evap drain tube.
Posted on May 23, 2009
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
My Hotpoint refrigerator is leaking puddles of water inside my vegtable crisper and on the floor, what can I do ?
It is most likely due to a clogged defrost drain. I put together some instructions on cleaning the drain, follow the link below and let me know if it was helpful.
Drain Leak
May 22, 2010 | GE Hotpoint Top-Freezer Refrigerator
Model PTB1953GRO Maytag Refrigerator-Water drips into
you might need to open the freezer wall and clean the drain hole.. it might be cluge... very EZ :)
take all out even the ice maker unit
take back wall out and see if the drain is cluge with ice or something...clean it and out it all back
Dec 31, 2009 | Refrigerators
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water accumulates under the vegtable and fruit bin
You may have a pluged drain tube and prevents the water from draining into the drip pan below the fridge.you will have to remove the tube from rear of fridge and clean.If you cannot get into the tube you will need to remove the rear panel inside the freezer compartment.and then pour hot water down from there till it breakes free.If your freezer is iced up you wil need 1of3 things first defrost timer second defrost thermostat third defrost element.Hope i helped:)
May 18, 2009 | GE J Series 20.6 cu. ft. Top Freezer...
Water build up in the bottom of the refridgerator under the fruit and vegtable cripser draws. maytag model #MTB1954ARW
Some causes are:
May 25, 2008 | Refrigerators
Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Dec 10, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
