Question about Toys
Bought a K B classics build & load track set. Was trying to put a battery in the car. When I took screws out of what I thought was the battery compartment the car fell apart with multiple gears inside. I can't figure out how they go back together.
Did you ever figure it out? we just did the same thing
Posted on Feb 17, 2011
250 watts k45ss classic stand mixer doesn't run
My first guess would be the speed control plate. It has three screws in an upside down triangular shape. The two screws on top control and adjust speeds 1 thru 6, and often times just one screw being out a 16th of a turn will shut the mixer off completely. I would venture that when you were removing the two stud bolts you moved the adjustment screws on the speed control plate. Remember that even a slight movement can shut down your mixer, take a phillips screwdriver and turn the top left screw one quarter turn while the machine is on, it can start on you so don't be shocked and jump with a loaded screwdriver in your hand at the back of an electrical device, stay calm, if no start then try the left screw a quarter turn, if it does not start go to a half turn on each screw, if still no start turn thr screws back to the start place and try the bottom screw a quarter turn left and right, if you do not start by now, then something is wrong in another place, go back to the brushes and take them out and check how you put them in, these are the two most common problems with a no start mixer. If this does not fix your problem or get the mixer to start please come back here with more info. If you motor raced in the first place then I would suspect the phase control board, but when it came back to normal speed it leades me away from the phase board. When the phse control board goes out the mixer only works at high speed. So please let us know so that we can help further.
Mar 28, 2013 | KitchenAid K45SS Classic Stand Mixer
Hi, I have a 2004 Vulcan Nomad 1500 L5 FI. I'm having issues starting the bike after I've been out riding for a while. It always took 2 or 3 revolutions (?) to start, but last season it sometimes took 4...
Hi
I would check the connection between the battery and the starter motor although its quite feasable that your starter is worn and is loading up, which makes it slow to turn and require more power from the battery.
Maybe you can remove the starter motor for testing?
Apr 24, 2017 | 2004 kawasaki VN 1500 Vulcan Classic
Bought a KB classics build & load track set. The small car fell apart when I thought I was putting in the battery. Instead when I unscrewed the car, the small motor just fell apart. There are...
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
Jan 01, 2011 | Toys
Deleting loaded tracks ie ones I've loaded
You should try taking the battery out. if you unscrew the for screws on the back there will be a battery just take that out and put it back in this should delete everything if it doesnt then i dont know. dont worry about takeing it apart your only takeing the back off to where the battery is. just like your cell phone.
Jul 13, 2008 | SanDisk Sansa e250 MP3 Player
Unable to charge
My wife spilled some water on her Pebl and she shut it off for the night. She dried it pretty good but it had a protective case over it and she thought that it didnt get water into the inside of the phone but it did. The next morning the phone wouldnt work. We left the battery out all day and yes, the "wet" dot had turned red. We thought all was lost, but that evening after it had dried we replaced the sim card and battery and turned it on and it worked fine....except it needed to be charged and when she went to plug it in we got the "unable to charge" msg and the phone shut off. Well, since I had bought the phone second off of Ebay I knew there was nothing that Cingular would do, I took the screws out of the back and took the phone apart. There is another one of those dots back there as well....and it wasnt tripped. I did notice a little bit of white stuff around were the battery prongs touch the main circuit board, I gently used the small screw driver I used to take out the screws and cleaned that stuff off. I also gently scraped those prongs and the metal they touch on the circuit board. Thought it was a long shot but I put the phone back together and plugged it in and bygod, its charging. Guess we will see how long this fixes the problem. Hope this helps you out some.
Jun 05, 2007 | Motorola Mobility Earwrap Handsfree For...
Toys Logo
451 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
