How do I remove cover to replace batteries for Hunter 44428 thermostat?
    Sergeant:
    Novelist:
  • 185 Answers
Shut the power off at the furnace...
Take both of your hands and start at the bottom and slowly start apply pressure at the bottom of the stat and it should pop off...leaving the subbase attached to the wall. Takes 3 AA batterys
Here is the Manual for this stat.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/44428.pdf
Posted on Jan 02, 2011
I have a Hunter 44428 Thermostat and even when the switch is in "Normal" mode (for heating), the display says "Emerg". Why does it say that? I even made sure it was definitely in "Normal" and not even...
your unit is likely equipped with an outside temperature sensor that switches the heat pump to emergency heat when the outside temperature is too low for the heat pump to work efficiently. This is common
Oct 29, 2013 | Heating & Cooling
Flashing number 2 code
Remove batteries.
Insert a paperclip or similar object into the "reset" hole and hold in for 10+ seconds.
Insert new batteries.
This should reset the thermostat to factory settings and clear all programs, and it should work normally afterwards.
If the error occurs again within a month, then call Hunter tech support at 888-830-1326 between 7am - 7pm US Central timezone.
Oct 13, 2013 | Hunter Fan Company 5/1/1 Programmable...
How do I change batteries in a Hunter airconditioner thermostat
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Dec 12, 2009 | Hunter 30124 Air Conditioner
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Switch a rheem thermostat to a hunter thermostat for heat pump
You can take the front cover off of your programmable thermostat. Unscrew approximately 2 screws that attach the base plate of the thermostat to the wall. Look in the back of the base plate after removing it from the wall to see how the 2 or 3 different colored wires (ex: red, green, black) are hooked up. Make note of this. Remove the wires from the back of the base plate and attach the wires to the same posts that they were connected to on the original base plate you removed. I believe the posts on the back of the base plates are color coded. (Ex: attach green wire to where it says GRN on back of base plate).
Make sure the thermostat that you are replacing and the new thermostat are similiar in shape, otherwise you will have make repairs to cover up a space that may appear around the new thermostat.
May 14, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat won't stay on, even with new batteries on hunter therm
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
Jan 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter therm
try to reset. if doesn't work properly, repalce the thermostat.
Jun 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
My Hunter thermostat that controls both my air conditioner and heating system worked fine for a couple of years. Then the date and time started getting out of whack. I replaced the batteries..problem still...
If the Hunter thermostat is 3 year old or more you will need to replace the thermostat. I have serviced HVAC systems for 20 years and see this problem all the time with hunter thermostats.
Mar 29, 2008 | Computers & Internet
Heating & Cooling Logo
1,198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
