Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Microwave (model jvm1850sm1ss). When I turned it on; it started making a funny noise and it was like sparks coming from the top. What can be going on.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Posted on May 01, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sensor Error, Funny Smell and Noise
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If none of these conditions apply to your situation, then you may have a defective sensor and/or magnetron.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Posted on Sep 06, 2008
  • 10865 Answers
SOURCE: GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
Posted on Jul 12, 2009
bestdarngood
  • 3037 Answers
SOURCE: Microwave GE Model #JE1640WB - Makes noise when
Magnetron is done. This part heats the food. GE microwaves tend to have them stop working quite frequently. They basically make up the majority of the cost of the microwave, so instead of replacing the magnetron, you would be better off getting a new microwave.
Benjamin
Posted on Jul 15, 2009
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
Stirrer Motor Part Number PS237771 GE Microwave
Quite possibly the Stirrer/ antenna motor. To Replace that, the outer cover of the machine must be removed. Unplug unit and take off the screws on the back of the unit and pull the cover back toward you and it will come off. The antenna motor is on the top of the unit and is only held on with 2 screws. You take off the two screws and lift it off of the unit. when replacing it you have to make sure the antenna is properly positioned on the shaft of the new motor to make sure it will turn properly. Not a difficult repair.
Oct 30, 2017 | GE Microwave Ovens
Microwave makes a funny smell when you start it also a popping noise
That sound like arcing inside the food cavity. Maybe it needs cleaning? or some contamination is flashing over making the popping noises.
Oct 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Problem with GE Microwave Model JES1358WK 02
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
q
May 30, 2009 | GE JES1358 Microwave Oven
Funny Noise coming from my microwave
Some of the soup got into the fan. You can continue to use it and hope the noise goes away on its own or you can have a techie clean it.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Mar 25, 2007 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
265 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
