Question about Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052
How do I change the frequency on the remote and the ceiling fan? We are on the same frequency as our neighbour.
  • 565 Answers
You'll need to find the dip switches. The dip switch for the remote is inside the battery compartment. You usually have to remove the batteries to see it. The dip switch for the fan is usually on top of the motor. It can also be inside the switch housing or the ceiling canopy. You can set the switches to any combinationan as lonf as they are the same for both.
Posted on Jan 04, 2011
Change frequency rc223 ceiling fan remote
sir the frecuency only can be alter if the fan has transformer inside TAP by 50 or 60hz. Otherwise, you must consult to the factory, if they have some transformer for installing with the TAP for o.k 60hz or 50hz whatever you will use.
God bless lyou
Aug 02, 2012 | Minka RC223 Remote Control
My ceiling fan/light goes on when I am not in the room. The remote is on the bureau. I sometimes put the remote in another room but the fan/light still goes on. Model 327185-060
The simple solution is to turn the wall switch OFF when, the fan is not in use. I really don't think the remote alone is the culprit. Because, you say it happens even when it's in the bureau or in another room. Remote controls for ceiling fans have a very short range and are generally infrared remotes, rather than radio frequency remotes. So, if the infrared signal does not reach the receiver's sensor in the fan, it won't function. If it's a radio frequency remote control, do you have any other remote controlled fans in the house? If so, does the suspect fan seem to turn ON after you have activated the other fan? If that happens, it means both remote controls are on the same frequency. Changing the frequency of one, should solve the problem. See your Owner's Manual for directions on how to reprogram the frequency codes.
If none of the above solves the problem, maybe you should contact the "Ghost Hunters" TV show.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | Hunter Heating & Cooling
Need to reassign remote frequency for a SMC OJ44V Ceiling Fan
As long as you have the pins in the same position on both the remote and receiver, everything should work fine.
Jan 06, 2010 | Casa Vieja Prelude White Ceiling Fan
Have a hunter ceiling fan with light kit and remote. Lights have started turning on and off by themselves ?
This is likely caused by stray frequencies in the neighborhood. Change the frequency on your system and see if the lights go off less frequently.
See the manual for the remote system. You'll need to go into the top of the fan and change some little switches (dip switches) and set the same frequency on the transmitter (what most call "the remote").
Charlie
Aug 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Apr 01, 2009 | Hunter 52" Ceiling Fan With Light And...
WE LIVE IN A CONDO AND SOMEONE IN THE COMPLEX HAS A hAMPTON bAY CEILING FAN WITH A REMOTE JUST LIKE US. wE MUST BE ON THE SAME FREQUENCY AND WHEN THEY TURN THEIRS ON IT WILL MAKE OURS COME ON WHEN WE HAVE...
Feb 18, 2009 | Universal Remote Control Hampton Bay...
Mind of it's own
your remote and fan is set to someone elses frequency by little toggle switches
you will have to remove fan to where it hangs make sure power off
find the remote sensor inside electric case at ceiling in the fan
this is a dip switch to control frequencies
09c4f2f.jpg you will see something like this adjust the dip switches
means change the dip switch for fan
then on remote open the remote battery pack find the dip switch in there
change those dip switches to the same as in ceiling fan
put fan together and turn back on power
your fan should now not pick up the other frequency of another remote and they have a span of about 50 yards to pick up frequencies
Jun 07, 2008 | Hampton Bay 24002 Ceiling Fan
Westinghouse Electric Ceiling Fan 3-way Light Switch By Westinghouse 77052 Logo
99 people viewed this question
Top Westinghouse Electric Electrical Supplies Experts
AJMAL KHAN
Gene Haynes
Terry Weaver
Terry Weaver
Are you a Westinghouse Electric Electrical Supply Expert? Answer questions, earn points and help others
