Question about Kuppersbusch 23 in. IGV6435 Built-In Dishwasher
Kuppersbusch Dishwasher IGV The machine very often does not finish the cycle. It gets stuck with 1 minute on the screen can anyone help
SOURCE: bosch dishwasher
HI,
I had this problem for a long time too, then I read the maual once I found it...and it says that if you have a water softeer, you need to use very little detergent, or the machine will continue to run, because there is still soap on the dishes. Also, I have the dishwasher with the stainless steel interior and it says that yo need to use powder detergent, not liquid and lastly you have to use a rinse agent. Once I corrected all three of the things I was dong wrong, my machine worked perfectly. I was about to get rid of the machine, but I am glad I finally sat down with the manual.
I hope this helps you.
Audrey
Posted on Feb 10, 2008
  • 171 Answers
SOURCE: Kuppersbusch IGVS 659.2/IGV 659.2/IGVS 649.2
Hi mike_poulton,
I'm Harvey the master Plumber.
Your question is: You have one of the above models and it has been a fantastic dishwasher but now it seems not to take in water even on rinse and the timer does not decrease.
Any ideas please the model is 6 years old and if too expensive to repaire it will sadly have to go.
This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 15, 2008
  • 8 Answers
SOURCE: won't drain after wash cycle
sounds like you need a new drain pump, call currys partmaster quoting your model number and ask them for a quote on a new drain pump they are really easy to fit, or a local engineer in your area ll fit it for around £35
Posted on Jun 27, 2009
  • 430 Answers
SOURCE: Cycle runs forever
Th Bosch units are prone to circuit board failure and this is the common symptom. If you are electronically inclined go the applianceaid.com and search Bosch for test codes to pinpoint the issue.There is an online picture of the faulty relay solder joint I repaired mine and a neighbors, Bosch will in some cases supply parts at no charge and they do not recommend repair, however IMHO it is a repairable cold solder joint very visible on the board. If you are good with needle tip soldering iron you are in luck
Posted on Sep 07, 2009
  • 3247 Answers
SOURCE: our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Posted on Jun 05, 2010
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Won't drain after wash cycle
Mar 05, 2009 | Kuppersbusch 23 in. IGV6435 Built-In...
The digital display is showing S2
try switching off the power for a short time it might reset itself
Jan 01, 2009 | Kuppersbusch K 24 in. IGVS 669.1 Built-in...
Hi mike_poulton,
Thank you,
Sep 14, 2008 | Kuppersbusch Dishwashers
Component failure
Put a bead of silicone on the tube connection and let it set up good before running. If the tube is in good shape and only comes loose this should be an easy fix.
Jan 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Message 007 displayed on right display
My kuppersbusch dishwasher drawer (detachable plate rack piece) is rusty. Where can I find a replacement?
Nov 08, 2007 | Kuppersbusch EEB 6800.0 JX Electric Single...
DISHWASHERHD98E
you have probably flooded the base of the machine and it now is in flood mode take side panel off and have a look and drain water away common fault
Sep 25, 2007 | Hoover 24 in. HD98E Built-in Dishwasher
Kuppersbusch 23 in. IGV6435 Built-In Dishwasher Logo
65 people viewed this question
Top Kuppersbusch Dishwashers Experts
Owen Barnes
Are you a Kuppersbusch Dishwasher Expert? Answer questions, earn points and help others
