Question about HP Pavilion a1630n PC Desktop
I have had this PC for roughly 2 years. During the first year (warranty period), problem arose, which resulted in my computer freezing up and eventually draining the power supply. During the warranty period, they sent me many power supplies, until the period ran out. Additionally, the image on the screen would freeze up and be completely distorted. The blue screen of death has recently popped up.The problem is yet unsolved, how do I fix this?
  • HP Master
  • 1,881 Answers
It's not new, its old, sure new to you.
what monitors does it use, Name and model #
what OS? what operating system run on it?
i guess you bought an old used PC what someone warranteed
they sound brave to me,, doing that,...
a1630n Desktop PC.
HP retired this desktop years ago.
https://support.hp.com/us-en/retired-products
I guess it runs XP OS.? or is it VISTA?
they sent me power supplies, well they sure did not for a destop
so that means it was for the unstated monitor.
Id say , lacking tests, or any photos of screen
that this is what is wrong.
1: bad monitor? (lines is my clue)
2: XP is totally virus infected as all are now, its a virus magnet.
HOw do you fix it, me?
well i test the monitor on an other pc first. if its bad we buy a new one. walmart has them for 36bucks
https://www.walmart.com/search/?cat_id=0&page=1&query=computer+monitor&sort=price_low#searchProductResult
once the montor works,
that BSOD , is next.
BSOD have many causes,
1: XP loves to BSOD at the drop of a hat, it is XP and that is its forte..
2: bad PSU in the PC, or bad memory in PC.
3: software corruption ,
if lucky the F10 key works on this PC
power on , press F10 and restore XP to HP day 1 , conditions.
XP is not supported by Microsoft now, for 3 long years.
nor updates, nor plug and play support.
what Id do is go to the GOODwill store, and pick out a
PC what has Windows 7 or newer ,used and rebuild that.
or these, they have refurbs, on pc's, almost new.
https://www.walmart.com/search/?page=1&query=refurbished+computer++&sort=price_low#searchProductResult
all with windows, 10
vastly more robust , safe , etc. and supported. 100%
Posted on Jun 27, 2017
  • 106 Answers
Two possible cause check ram memory or the main-board is bad. ram makes the p c to freeze
pjszilard
  • 72 Answers
SOURCE: video freezes up to vertical lines or blue or white screen
Clean the CPU cooler and everithing else from the dust!
Turn off,open the case, use air spray to clean.
(I use vacom cleaner and a small brush, but you risk your component if you do the same! I'm professional.)
Posted on Nov 28, 2007
SOURCE: Computer will not turn on. Power supply shows flashing green.
depending on the make of computer, a power supply cost's around $20.
Posted on Mar 15, 2009
Ownij
  • 67 Answers
SOURCE: pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Posted on Mar 16, 2009
  • 26 Answers
SOURCE: My HP Media Center 1170n keeps freezing up on me
Try opening the sides of the computer and running the computer, If it still freezes, look inside and see if any of the fans turn off at any time, if that Happens try pushing it to make it go, if that doesnt solve it, try replacing the fan. Buy the fan at TigerDirect.com
Posted on Jun 17, 2009
sparky1500
  • 1066 Answers
SOURCE: Computer died - will not reboot - even to show system bios.
motherboard or cpu failure. or possibly power supply.
Posted on Dec 27, 2009
Garrison RCT100 DIGITAL TIMER
Yes.
Timers usually don't last more than a few years, unless you buy the heavier duty box timers that last decades.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Dec 20, 2011 | Hardware & Accessories
Vertical lines
I called a local tv repair shop he said that he'd have the see the unit to give an exact price but their labor rates were from $79.95-$179.95 + parts =(
Jan 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I purchased an $800. Maytag dishwasher: MDB5701Aww10445767NE E39927 Type 777-0 July 2008 for our cottage. It hardly gets used during the winter so when it quit working at the beginning of July this...
im sorry to here that ,but i did a little research for you,,,that model number did not run the closest i could get was mdb5601aww .but that does not matter what you need to do is check your warranty
that came with the unit i believe you were under warranty for the parts...its in your owners manual..i think electronic control is warrantyed for 2- 5 years...it might sound strange but if you let you appliance just sit for long period of time, after they have started they can freeze up...good luck
Sep 10, 2011 | Dishwashers
Gas leak no solution refuse to pay rx 6000 when it is in the warranty period t
Actually, all air conditioners having compressor warranty for 5 yeas and comprehensive warranty for one year only. If your a/c under gas leak during comprehensive warranty period, you have rights to ask the manufacturer/supplier to do free gas charging. Check your warranty details and date of purchase.
Dec 13, 2010 | Heating & Cooling
I purchased an HP Pavillion Slimline S3620f model# FK785AA-ABA Serial # CNX8330324 - KQ511-69002 Mother/system board FK563-6900Intel Core 2 Duo Processor #5200 2.5 Ghz Kc923-69001 2G Memory mododule...
ohh hp pavillion have 2 year warranty on the motherboard, but dont do it yourself, just call the customer care and ask them to resolve the issue, as system is still in warranty period, dont void the warranty yourself
Feb 09, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Check engine light indicating a need to replace the catalitic converter. What is the warranty on catalitic converters
usually 100,000 miles , some are 70,000 miles. just call your local toyota dealer parts or service dept. , or look in your owners manual under the warranty section of your manual.
Good luck with your problem
Oct 01, 2009 | 2003 Toyota Corolla
Guranteeofasustekmotherboard
http://support.asus.com/service/service.aspx?no=231&SLanguage=en-us
Motherboard 3 Year Since 2000/1/1 onwards Notebook 2 Year Since 2002/2/1 onwards Portable PC (Degatto PC) 1 Year VGA Card 3 Year Since 2001/1/1 onwards (3 year warranty)
Prior to 2001/1/1 (1 year warranty) CD /DVD /CD-RW /DVD-RW Drive 1 Year Server 3 Year 3 year warranty coverage on ASUS' full system. Applicable only to components with genuine ASUS label sticker installed on ASUS Server. Warranty period is determined by the serial number on ASUS Server. Wireless Products 2 Year PDA 2 Year Since 2003/2/18 onwards
Dec 27, 2008 | Computers & Internet
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Warrenty
2 Years.
From TomTom's web page:
U.S. and Canadian Purchases: If you have made your purchase in the United States or Canada, this Limited
Warranty is granted by and this Limitation of Liability is stipulated for the benefit of TomTom Inc., 150 Baker
Avenue Extension, Concord Massachusetts 01742 (United States of America).
WHAT THIS WARRANTY COVERS
1) TomTom Inc. (“TomTom”) warrants to the original purchaser (“you”) of the hardware with which this Limited
Warranty is included (“Hardware”) that the Hardware will be free from defects in workmanship and materials
under normal use (“Defects”) for a period of two (2) years from the date that the Hardware was first purchased by
you (“Warranty Period”). During the Warranty Period the Hardware will be repaired or replaced at TomTom’s
choice (“Limited Warranty”) without charge to you for either parts or labour. This Limited Warranty covers the
replacement of the Hardware only. If the Hardware is repaired after the Warranty Period has expired, the
Warranty Period for the repair will expire six (6) months after the date of repair.
Sep 16, 2008 | Tomtom GPS
Hard Disk Problem
Likely the drive has failed. First check the cabling, and settings in BIOS. Is the drive being detected by BIOS during bootup? Next see if Samsung has a drive diagnostics program which can be downloaded and run. This will usually tell you what is wrong with the drive, if anything.
You can do the process of elimination- Install a known good drive in your computer, take the suspect drive and install it in a spare or a friend's machine.
If it is bad, replacement is required. Any data on it is probably toast unless you wish to employ the expensive services of a data recovery business.
Jun 18, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
HP Pavilion a1630n PC Desktop Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
