My esc dvd-690 will not detect my usb-key after i have formatet it. writes device not supportet
5 Suggested Answers
  • 128 Answers
SOURCE: need code for universal remote
I don't believe ESC is supported - most portables are not - as far as the Relissys try code 580
Posted on Nov 24, 2008
SOURCE: this is what happens: after all
For that open back cover of cpu. Then reconnect RAM memory. Pull cmos cell from motherboard for 10 minutes. Reconnect processor and it's fan also reconnect both connection to harddrive. Make sure motherboard is not ground with cabinet. Then check Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 05, 2010
elix0411
  • 3530 Answers
SOURCE: i need manual for conecting
Welcome to Fixya
Connecting a dvd player to your tv depends on what type of cable or connection you are going to use. Here's the procedure using different cables to connect to your tv.
    Component Video Connection
  1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
  2. Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
  3. Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
  4. Match the connectors to the appropriate video input jacks on the TV.
  5. S-Video Connection
  6. Get an S-video cable. This cable has a single round connector with 4 pins.
  7. Attach one end of the S-video cable to the S-video output jack on the DVD player.
  8. Attach the other end to the S-video input jack on the TV.
  9. Composite Video Connection
  10. Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
  11. Plug one end of the composite video cable into the composite video output jack on your DVD player.
  12. Plug the other end into the composite video input jack on your TV.
Thank you for using Fixya!
Posted on Feb 07, 2011
  • 6771 Answers
SOURCE: Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Posted on Jul 06, 2012
Testimonial: "I fixed problem myself... I downgraded bios to oldest version... pc now working... and u know what? *uck U ASUS! Asus bios files are bugy! My friends pc was good until warranty end.... after warranty pc started to do sh*ts.. I had to insert older version of bios??? TFW ASUS?? but thx for morale boost, good luck to you..."
Samsung USB 2.0 Ultra Portable External DVD Writer Model SE-218CB/RSBS maanual
There are some Hardware technical issues i think.
If your DVD not write any disk then may be leans damage or dust in leans.
If your USB not proper detect or working then not any write DVD.
If your windows USB Driver not installed then not proper detect you USB devices.
So please check it your windows performance or also check it Virus in windows.
And i share a informative link please visit and read it, i hope solved you issues.
http://support.microsoft.com/mats/cd_dvd_drive_problems
http://www.computerhope.com/issues/ch000227.htm
Thanks,
Mac Technical Support
Jun 10, 2014 | Apple iMac Computers & Internet
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Jul 06, 2012 | ASUS Computers & Internet
HP Atom/ win32 /boot.ini filies corrupt or missing??? Need Startup disk in USB Boot ???? No Rom drive !
Your going to have to contact HP and organise a reimage through a HP agent ot purchase your own copy of Win7 Home premium 32bit plus a USB dvd rom when you have done that power your unit on hit the ESC key or F9 to select a boot device in this case select DVd rom make sure your win 7 dvd is in and carry out a reimage
Jul 09, 2011 | HP Mini 210-1030NR Netbook
My dvd rom is not recognized
Check in BIOS if your dvd drive is recognized. To go to BIOS, do the following:
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
If your dvd is not present on the list of bootable drives, it means that the drive is not detected. Try to reseat the drive. If the drive is still not detected in BIOS it means that drive is failed and needs to be replaced.
Nov 12, 2010 | Toshiba Satellite Pro L300 Notebook
Can not detech and write
there could be a problem with the usb check if you are able to use any other humb drive or flash drive on the sysem if none is getting detected then just go to device manager and uninstall all the usb drivers and then resart the system it will get installed automatically nothing to worry then you can again try and see if it gets detected in the system tray and als after it gets detected install the dvd software to use it to write/read
Oct 26, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Same dvd player. lost remote. don't know what to do.
Hi jochensetzer
I see that you also own a esc dvd-690 player. I have one too. Unfortunately I have misplaced my manual, and I need to know how to use the USB port on the player. I tried sticking in my thumb drive, but it wouldn't read it. Do you know if theres something special about the USB, that you need to know before using it?
Jul 23, 2009 | Universal Remote Control Remote Control
MY DVD/CD DRIVE DOES NOT WORK IT WILL NOT READ THE DISC cannot play dvd,cds or load or make dvds or cds
Open the drawer.
Insert a disk, rotating the disk so that the writing on the face of the disk is "level".
(Imagine a clock-face on the disk; rotate the disk to make the writing go from "9" to "3",
not "10" to "4", nor "12" to "6".)
Close the drawer.
Wait a minute (to see if the disk should automatically start spinning).
Hold down the "Windows-flag" key on your keyboard, and touch (once) the 'E' key.
Wait a few seconds.
Open the drawer.
Is the disk still at the "9-to-3" position?
If so, then the CD-drive has *NOT* read the disk at all, and it needs to be replaced.
Try the above with the same disk in another computer, to see how it _should_ work.
Then, shutdown your computer.
Turn it on.
Look for the message: "Press DEL to enter setup".
Quickly, press the DEL key.
When you see the "setup" menu, press ENTER.
You should see at least 4 similar lines:
AUTO ... AUTO
AUTO ... AUTO
AUTO ... AUTO
AUTO ... AUTO
If you see 'NONE' anywhere, press the TAB key (or the DOWN-arrow key) until that 'NONE' is highlighted, and press PG-UP/PG-DOWN until it changes to AUTO.
Repeat for each 'NONE'.
Press ESC once to return to the "main-menu".
Press RIGHT-arrow and DOWN-arrow to highlight the "Detect Drives".
Press ENTER.
It should auto-detect your CD-drive, within 1 minute.
When it's finished detecting, press ESC.
Use the "arrow" keys to select 'SAVE CHANGES'.
Select it, and save the changes.
Let it reboot.
Now, is your CD-drive working?
Within Windows, hold-down the "Windows" key, and (once) touch the 'E' key.
Do you see an icon for the CD-drive?
If not, then the CD-drive is *NOT* physically-connected (either ribbon-cable or power-cable) to your computer's motherboard.
Apr 22, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
Need code for universal remote
Nov 22, 2008 | Universal Remote Control Remote Control
Problem with dvd/cd ram does not detected cd
CD Recording software that comes with HP and Compaq computers is made to recognize only the original CD and DVD drives. If a new CD or DVD writable drive was added, use the software that came with the drive or purchase and use new CD writing software. If you are using Windows XP, you can use Windows XP itself to create CDs (not DVDs). CD or DVD drive is not recognized by Windows If the drive is missing in Windows, remove all connected USB, firewire, and parallel devices and perform the following steps to enable the drive in Windows: Step 1: Checking for CD/DVD drive in BIOS Make sure the drive appears in Setup. The drive has to be detected in the Basic Input/Output System (BIOS) before Windows can see the drive. Check for detection as follows:
  1. Turn on the PC. When the first logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may be different, F2 or Del )
  2. Press the F5 key, and then press the Enter key to reset the BIOS to the defaults.
  3. Use the Left and Right Arrow keys to select Main .
  4. The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
Feb 21, 2008 | HP Pavilion a1010n (PS563AA) PC Desktop
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
