Question about Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer
How do I remove a label stuck under the tear bar?
My elderly neighbour has a sticky label stuck behind the paper roller and I don't seem to be able to life up the front of the typewriter to be able to clear it.
Depending on the typewriter model, most all have release points located on either end of the roller bar. Locate these, push forward or backward, release roller bar and lift the bar out. This would be the preferred solution, as it would make removing the sticky note far easier. These release points will look like small levers and should have directional arrows visible to indicate which directions they should be pushed to release the bar. If you cannot remove the roller bar, I suggest standing over the typewriter and use a pair of tweezers to remove the sticky note. It may take some patience, and may tear, but eventually it should be able to be removed,even if it is bit by bit. Also, with each portion removed, turn the roller bar to make the remaining part of the note more visible. Good luck.
Jan 11, 2016 | Brother AX-100 COMPACT TYPEWRITER
How do i adjust the printer to the tear off position
Print a config label by holding the cancel button and powering on 15seconds. Check print mode = tear off. If it is in rewind mode the label stops under the print head and does not backfeed before printing. Tear off pushes the perf to the tear bar and backfeeds before printing.
Dec 19, 2012 | Zebra S4M Thermal Label Printer
Sato cl408e - printing over perforations. I tried turning the Pitch(all the way to the right) and Offset(all the way to the left), and this helped a little, but still not right. Because of this, when the...
Reset printer sensor threshold setting.
Turn on printer whilst holding down line key untill printer beeps.
Use feed key to step to Gap in display.
Load label plus backing under sensor and not volts reading.
remove labels and place backing only under sensor and note volts reading.
use following formula
High reading + Low reading / 0.5 = Value to use
e.g 2.8 + 1.4 / 0.5 = 2.1.
use result to change value of input using line key once set press feed key to set.
To change label start position use the pitch menu.
Jun 02, 2011 | SATO CL408e Thermal Printer
I have a TA Adler-Royal 315. It operates beautifully, and hopefully will continue to do so (fingers crossed). Someone used it recently when I was away from the office and managed to get a label stuck to...
Try this thke a piece of heavy stock, like a file folder and force it thru the paper path while turning the platen. This may push the label thru or at least flatten it out.
DickyO
Mar 09, 2011 | Royal Office Equipment & Supplies
Zebra 90XiII - sometimes when adjusting the tear off position using the arrow keys. The printer (motor) doesn't move the label media in/out. When it does actually move the label media to the desired...
Print a configuration label and see if it is in the correct mode - tear off mode. If it is in rewind or peel off, then the label is not suppose to come out to the cut bar, but stop under the print head and not backup.
If you want it to align with the cut bar make sure that the driver is set for tear off with backup enabled. The printer driver in the software will override the printer setting and change it as soon as you send a print job.
Dec 02, 2010 | Zebra 90XI II Printer
Why does the label wrap around the bar every other label I print?
possible becouse the tear off position stop the gap on the wrong spot and wen you cut the label, left some label with glue expose, and wen you send other print, the printer make the backfeed and the label go stuck on the white rollar.
go througt the setings to TEAR OFF, and ajust to the front or back, untill hav the best gap/label rest possition and cut proply. don't forget to save (press setup button twice)
May 10, 2010 | Zebra Z4Mplus Label Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Oct 19, 2009 | Zebra QL420 Thermal Printer
Paper pulling at an angle
I not sure of which bar you are talking but,try getting a pair of long nose pliers that are curved at the endand see if you can get to it that way?
Aug 05, 2008 | HP LaserJet 1022 Printer
Z4MPlus barcode printer
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Dec 27, 2007 | Zebra Z4Mplus Label Printer
Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer Logo
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
