Question about GE Washing Machines
GE washer wwse5240g0ww spin cycle very slow, agitator also very gentle - not agitating strongly.
  • 184 Answers
SOURCE: washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Posted on Apr 10, 2008
MNfisherman
  • 11896 Answers
SOURCE: ge washer won't agitate
If the washer won't agitate at all, but the motor and belts are turning,
then you may have drive coupling or transmission issues. In this case, it
is well worthwhile to have a technician check the machine to verify this.
Sometimes, the base of your agitator can strip out, especially from
overloading. In such a case, the splines are damaged inside the agitator,
and can be seen after the agitator is removed.
If you can hear the motor running, and the water is moving a little bit, but not like normal where the clothes are being worked around you might just have worn out agitator dogs. This is a really easy 15 minute do it yourself fix, and the parts are less than $10 and widely available. Here is a how to article - http://zenfixit.com/repairs/appliance-repair/washing-machine-agitator-clutch-repair/
Posted on Feb 01, 2009
  • 3 Answers
SOURCE: GE washer WJSR4160G0WW agitation is way too fast & hard
check the 4 rubber cords at the top of the tub. If the washer has been moved they may need to be adjusted, you can see them by looking between the top of the tub and the top cover. You can turn them with your hand, and you may need to tighten them after.
Posted on Sep 21, 2009
lscf150
  • 443 Answers
SOURCE: GE Washer WWSR3090T8WW does not agitate
Sounds like a transmission failure to me?
Good Luck !
Posted on Feb 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer agitate very slow
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$^#%&
Posted on Oct 01, 2010
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
Washer will do everything but spin out and agitate belt good can rotate with hand but on the belt will not spin on pulleys air coupler is good and threads are excellant any advice
Since spin and agitate are the two times the transmission is used, that is what I would look at that. The agitate is the slow cycle of the transmission and the spin is the high cycle. Can you physically view the belt, i.e. that you have things opened up?
Jun 08, 2011 | GE WDSR2080D Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Good Luck !
Feb 10, 2010 | GE Washing Machines
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Jun 07, 2009 | GE WJSR4160DWW Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Loud spin cycle
There is a good chance that the hub nut came loose and now the split ring is destroyed, maybe along with the hub that it sits on..
To inspect these parts, the agitator must be pulled sharply and abruptly off the agitator coupler. There are no mechanical fasteners that attach the agitator to the coupler, it snaps on. A strong strap under the agitator and a quick, swift pull will remove the agitator.( Don't hit your face, it hurts)
Removing the coupler, then the basket should reveal the source of the noise.
Jun 23, 2008 | GE Washing Machines
Washing Machines Logo
105 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
