Question about Dishwashers
What is E24 on my Bosch super silence dishwasher?
    New Friend:
Folks, it's draining well but still E24, any ideas? Any class suit aginst bosh?
Posted on Jun 24, 2016
    New Friend:
Make sure the line from the dishwasher that is going into the garbage disposal is point upward. Sometimes items under the sink may hit this line and it may now go sideways or down and the dishwasher can't drain properly because the sink water is now glogging the dishwater drainage. Check this simple fix first before having to break out the tools.
Posted on May 04, 2016
Check the air gap! It may be clogged.
There is a great video explaining how to do t linked below.
My air gap was clogged, and after cleaning it the error 24 was gone...
The Diswasher Air gap how to clean it and why it important
Posted on Nov 21, 2014
5 Suggested Answers
SOURCE: bosch dishwasher lfestyle automatic runs for 1 min
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Posted on Mar 31, 2010
SOURCE: bosch dishwasher has e24 error code and does not
An error 24 code on your Bosch dishwasher means that you have a clog or that your pump is bad. Check and clean out your airgap. If that doesn’t work and your machine is still under warranty, call Bosch. Bosch won’t tell you what the error code means, only that you need a service call, and they will then give you some phone numbers for Bosch authorized appliance repair places, one of which was Mr. Appliance. The appliance repair place will want to put in a new part whether you need it or not so that they can get paid by Bosch. I found this out the hard way. Hey Bosch, be smart and tell your customers what the error codes mean so that they are informed and you don’t look like you are trying to rip them off. Leave that to Mr. Appliance. You can always remind the customer that working on the actual dishwasher voids the warranty. It doesn’t take a rocket scientist to figure out how to clean out the airgap, which isn’t a part of the dishwasher, but rather part of your plumbing connected to the dishwasher. I suspected this to begin with, but because you told me I needed a service call, I had to assume it was beyond basic owner maintenance. Great way for you to flush money down the toilet and look bad doing so.
Posted on Apr 30, 2010
  • 608 Answers
SOURCE: I have a bosch dishwasher
Error code 24 for a bosch dishwasher is either a bad pump or a plugged drain or airgap. This is where your washer connects to the plumbing system. If you are under warranty have it fixed if not I would start by seeing if your system and make sure it isn't plugged first. After that it could be the pump has failed.
Hope this helps
Posted on Dec 09, 2010
Daniel S
  • 4323 Answers
SOURCE: My Bosch Eco Sense dishwasher shows error code
Hi
E24 error indicates draining failure and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Jun 20, 2011
What is E24 on a Bosch dishwasher?
Go to Bosch web site to find out the significance of that code and then address it. If parts needed go here Search Over 2 1 Million Appliance Parts
Sep 08, 2017 | Bosch Dishwashers
Bosch silence plus showing fault E24. Have lost our manual . How do we fix this ?
Check the manual online:
https://www.manualslib.com/products/Bosch-Silenceplus-She45r55uc-3787557.html
Jul 01, 2017 | Bosch Dishwashers
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Sep 05, 2016 | Bosch Dishwashers
Bosch silence plus 50 dba dishwasher not draining it says E24
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Mar 02, 2015 | Bosch Dishwashers
What does E24 mean
try to display also your model no. it could be something different.
E24 Drain filters blocked. Clear the filters. Generic instructions to clean your dishwasher filters is available from here.http://www.ukwhitegoods.co.uk/help/fix-it-yourself/dishwasher-self-help/2813-dishwasher-general-care-a-maintenance.html
Dec 11, 2013 | Bosch Dishwashers
Code E15 bosch super silence dishwasher
Use dish washing rug and soak water out trough salt inlet. Only 10 degrees tilt needed. Boch Super Silent dishwasher. E15 error code.
Mar 02, 2013 | Dishwashers
Dishwasher will not run, gives a message "E-24"
Feb 12, 2012 | Bosch Dishwashers
Bosch dishwasher lfestyle automatic runs for 1 min then displays e24?
Mar 31, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
8,950 people viewed this question
Top Dishwashers Experts
