Question about Linksys Wireless-G Range Expander (WRE54G)
I have linksys wre54g version 3.0 range expander and a cisco wap4410n router. Can't configure the expander site survey failed message. please help.
4 Suggested Answers
mastersaintx
  • 928 Answers
SOURCE: Linksys Wireless-G Range Expander WRE54G does not work
Yes you can call Linksys about it if it is under warranty. Warranty is 3 years. Most likely just a configuration problem. Just give Linksys a call and they should be able to get you up and running
Posted on Jul 28, 2008
marked
  • 6487 Answers
SOURCE: Linksys WRE54G WIRELESS 802.11G RANGE EXPANDER Range
The actual max distance of the range expander is about 50 feet, and sorry to say but it cannot bounce the wireless signal from it on a wall....
Posted on Jan 25, 2009
  • 10406 Answers
SOURCE: When I connect my Linksys
> Site Survey fail
It's your wireless adapter that is "sniffing" for available Wireless Networks, and is finding NO networks.
Disable your wireless adapter, and connect the Ethernet cable, to exclusively use the "wired" connection.
Posted on Jun 06, 2011
Can my wre54g range expander work with a wireless N router
"Using a Range Expander is not recommended if you have a Linksys Wireless-N Router." This info was found at the bottom of this link under the note.
http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&docid=afe65b013aea4e1a92424e635a6aa619_17831.xml&pid=102&slnid=3
I found a list of router that it should work with. All the routers listed are G routers though.
http://homekb.cisco.com/Cisco2/ukp.aspx?vw=1&docid=11a933a7173b4f31b43f21dde626becb_1486.xml&pid=102&slnid=3
You should check to see if you router model # is in this list.
Cisco owns Linksys FYI.
Hope this helps you. Even though it says that it is not recommended to use it if you can still try it to see if it works. You can always go back to the way things were.
Aug 27, 2012 | Linksys Wre54g wls g range expander...
When I connect my Linksys WRE54G to PC with lan cable. Always get the message "Site survey fail"
> Site Survey fail
Jun 06, 2011 | Linksys Wireless-G Range Expander (WRE54G)
What range expander should I use with a Linksys Dual Band Wireless-N Router Model WRT 320N?
For this router you can use the Linksys range expander model WRE54G v3 take not of the version number that is important since the older range expander don;t work on all routers.
Feb 13, 2011 | Linksys WRT320N Wireless Kit
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Site survey failed
You can connect your expander to your PC via ethernet cable and then assign a static IP address on your PC.
To assign a static IP address, just double-click on the monitor icon on the lower right hand corner of your PC and then view status and go to properties. Look for TCP/IP v4 and click properties.
Select use the following IP address:
192.168.1.2
255.255.255.0
and then click OK.
After successfully assigning an IP address to your PC, let's test the connectivity by going to command prompt.
Go to Start>Run>and then type cmd and hit Enter.
Once you're on the black screen type ping 192.168.1.240.
If you get replies then your good to go...
Let's now access the Web UI of the you Wireless expander.
Open a browser and then type on the address bar 192.168.1.240 and then hit enter.
It will prompt you with WRE54G's username and password. Just type the password to login to the Web UI. The default password is admin.
Once your on the Setup page, you have to configure your settings exactly the same as your wireless router (e.g. wireless security, IP address range) except for the SSID. You may want to change the SSID on your WRE54G for you to easily identify where your wireless computer is connected.
You can leave the WRE54G's IP address to 192.168.1.240 if your wireless router's IP address is on the same range like 192.168.1.x
Then on the Gateway address type your router's IP address. If you're also using Linksys the default IP address usually is 192.168.1.1
Then you can configure your wireless settings same as your router. After that, same the settings and see if the light on the WRE54G becomes BLUE. If yes, then you're good to go! You can unplug the PC from the WRE54G and then set your PC's IP address back to Obtain an IP Address Automatically. See static IP address procedure above.
Jul 06, 2009 | Linksys Wireless-G Range Expander (WRE54G)
When running the setup CD, I get a Site Survey failed. Anyone have any ideas?
I can help you configure your expander manually instead of using the CD.
192.168.1.2
255.255.255.0
and then click OK.
Jun 09, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
I just bought a Wireless G Range Expander and when I try to set it up, I continually get the "Site Survey Failed". What am I doing wrong?
I believe your using a WRE54G, but which version? The latest version has ethernet port so you can connect it directly to a pc to set it up.
Try to access the expander's set up page by typing its address of 192.168.1.240 and you will be able to configure it from there.
Jun 25, 2008 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Range Expander...
Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
3. Power up the LinkSys Expander;
4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
5. Power off;
6. Move the Expander to your intended place of installation;
7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
8. Move your daughter's laptop to its intended location and try the system.
Should you still need a User's Guide, it is available here.
Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G Range Expander (WRE54G) Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
