Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
Saeco Talea Ring I'm getting 4 oz. single shots of espresso??? Don't know how to adjust. Tried every item in Manual. It worked great for a year or so. Thanks, Jerry
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
Clarification: It complains constantly. Even when I empty the drip tray, which is already empty, put it back in (empty) - it still wants me to "empty the drip tray" again. Sometimes - if I'm lucky - I can brew 1 espresso before it wants me to empty the drip tray.
Thank you for your assistance!
Posted on Jul 11, 2008
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
  • 20 Answers
SOURCE: Saeco Talea Ring Plus
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
Posted on Dec 23, 2009
  • 81 Answers
SOURCE: Error Code 4 on Saeco Talea Ring
error code 1 means the grinder is not working, either the motor is bad or there is no power supply to the motor.Have to take it back to the Seaco service center.
Posted on Mar 06, 2010
What is the purpose of the 3rd position on the steam knob. no info in manual
The 3rd position on the steam knob is for a separate item call a 'Milk Island" which has a small jug attachment that you put milk into and then froths up for cappucinos. It is fantastic and works 10 times better than the steamer wand. It does a great job with lite milk. Item is sold separately, don't know how much it is as I got it as a gift. Hope that helps you.
Jul 01, 2011 | Saeco Talea Giro Espresso Machine
Out of service [4] out of service [87] restart to solve the problem SAECO TALEA RING PLUS
Hi...itis not self testing..in otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
Dec 04, 2009 | Saeco Talea Giro Espresso Machine
Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
Aug 23, 2009 | Coffee Makers & Espresso Machines
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Weak coffee shots
Need a decent grinder or a deft hand with a blade frinder, fresh espresso coffee beans and not too much water. Espresso grind is closer to turkish than drip. Much like Melitta grind. If needed a good coffee shop will grind it for you. A week suppply is preferable. If quantity of water can be adjusted, one shot is about 1&3/4 oz. a double shot, well x2=3.5 oz. You cannot get a six ounces espresso and still call it that; its dilluted or "allonge". A latte w/o milk. Let me know
Dec 29, 2007 | Saeco 762111651808 Espresso Machine
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
41 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
