Question about Kenmore 16919 Built-in Dishwasher
Won't unlock even after hjolding unlock for four seconds as recommended
I nedd to unlock my fpa on my RCA flat screen model 20V500T
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 26, 2012 | RCA Televison & Video
The FDA is lock and the TV wont stay on
Hello
The lock of RCA TV can be unlocked. You must have its original remote control to do this. If you haven't one, buy a new one or just borrow it from any of your friends or relatives who own the same model RCA TV you have. To unlock it, try these methods. One amoung them will surely unlock your TV.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Sep 23, 2011 | RCA TruFlat 27F520T 27" TV
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
Jun 09, 2011 | Televison & Video
Forgot the parental code how do we reset
Hello
Just unlock its Parential contol and reset the TV. NB: You must have its original remote control handset to proceed. If you haven't it with you, just boroww it from somone you know, who have the same model number of Tv; just to unlock it. After unlock, you can use universal remote or so.Proceedings are:
Most GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Jun 02, 2011 | GE GTD120 System
How to take of the FPA on a RCA 27V412T
Hello
To unlock the FPA lock of RCA tv, do the following. One amoung the process will surely unlock your RCA. You must have its original remote control handset to do this..
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
May 22, 2011 | Televison & Video
How to unlock a rva Tv
Hello
To unlock an RCA tv, you must have its original remote control handset with you. If you have it, do the folloing methods. One amoung it will surely unlock your TV.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds.
OK.
May 19, 2011 | RCA Televison & Video
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
May 06, 2011 | RCA Televison & Video
I was trying to look for the input, and accidently locked the screen
You will need to have the remote:
Press the VOL+ on the remote control and the CH+ button on the front of the TV.
The TV will prompt you to enter a new password.
May 03, 2011 | RCA TruFlat 27F520T 27" TV
My TV 13GP341 access code calls me, what should I do?
Hello
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
OK
Apr 26, 2011 | GE 13GP341 13" TV
Open Questions:
See all Kenmore 16919 Built-in Dishwasher Questions
Kenmore 16919 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
