Question about LG VX5300 Cellular Phone
Car Kit will not shut off
The "car kit" icon will not allow me to receive phone calls- no "car kit" wqas ever used.
  • carkit Jul 09, 2008
    tried the knife thing no luck.....
  • msimpson36 Jul 30, 2008
    Not sure what to try carkit comes on and will not allow you to use the phone please help.
This means it got wet... it's water damaged... get a new phone.
Posted on Jul 29, 2008
I wiggled a knife in the right side of the charger port like the other guy said and it worked!
Posted on Jul 15, 2008
My phone has no sound, and it now says "-Car Kit-" WHY?
Firstly i come to your 2nd question where you asked what the meaning of Car Kit. Bro Car Kit means a sound system which contain also blue tooth, DVD, FM etc. So in Car Kit any one can pair their blue tooth devices i mean your cell phone where blue tooth are available. So when you pair your device at the define range then Car Kit will be connected with your phone so when your receive or dial a call then the Car kit speaker will be active automatically. You can hear voice from there.
Now come to your next question,
If your Car is off or you are so far from car then your speaker will be enable normally but if it don't work then means your speaker disable or inactive. As a result, you have to change your speaker by a expert technician then you will release from this problem. Thanks a lot
Nov 09, 2012 | Cell Phones
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
Parrot will allow me to make a call but does,nt allow through speakers calling or receiving
when you receive a call press the green button to see if your mobile is paired with the kit. You can simply put the battery of the phone out during a minute and put it on again. The emulation between both devices can clear the trouble.
But that can be also a question of install so do you have the same trouble since the begining?
Did you install it by yourself?
Cause it maybe in relation with the install.
Jan 17, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Nokia 3109c with Bury car kit. Phone and car kit
Lawson,
did you solve the problem?
I have a similar problem, I can hardly hear my Nokia 3109C at full volume in the Bury carkit. The workshop told me that their Nokia worked fine, they suggested installing new firmware on my phone, however I have the latest version installed (7.21).
Hans
Jul 31, 2009 | Cell Phones
LG Phone has Car Kit Error. Didn't Get Wet. Can I Clear it
Dear customer,
                     To Remove “Car-kit” error there are few ways:               What worked for me as suggested by chemist  is using Calcium Chloride (CaCL2) as a drying agent since it pulls moisture out of the air, and according to Verizon, this car-kit error is caused by exposure to moisture. For the average person, you can find this in the form of “Prestone Driveway Heat Concentrated Ice Melter” (or other ice melter – check ingredients).
1) Pour about 1 cup or so of CaCL2 in a small Tupperware container.
2) Place a sheet of paper on top of the CaCL2 to protect the phone.
3) Place the phone on top of the paper so as not to allow phone to touch CaCL2 (this is important).
4) Place the lid tightly on the Tupperware container.
5) Allow to sit overnight.
In the morning, the “car-kit” error was gone! Yay! I could could hear my callers, they could hear me, and I could hear all my ringers.
                         Other suggestions that  might work for you are.
         Car Kit
 To remove errors from phone:
#1) press soft key for menu
#2) then press 0
#3) you'll have a service code prompt, type 000000
#4) then type 2 (it should be field tests)
#5) then type 4 (clear errors)
#6) choose yes for clear errors
#7) press clear once
# type 8 (FCC test)
#9) type one (pcs)
#10) type one again (set channel) (mine shows 426 I don't know if theres a different channel for each phone.)
#11) press clear 3 times and the phone will reset.
                       FOR RESTTING
Enter "Menu"
Select "Settings"
Select "Security"
Enter "Lock Code" - Will default to last 4 digits of phone number or "0000" unless changed.
Select "Reset Defaults"
Press "Ok"
Plz rate this solution.. thank you..
Apr 09, 2009 | LG VX8300 Cellular Phone
Just got CECT P168 & paired it with the handsfree link in my car & I can receive calls through my car, but when I make a call the car hangs uo and the call coontinues on the cell phone. What should...
Unfortunately it sounds like the phone is not compatible with your phone-kit. Have you tried the phone with another bluetooth kit or headset? Also, you should try another phone with the car kit to make sure the problem isn't there.
Jul 25, 2008 | Cell Phones
Says Car Kit on phone but has never had a car kit hooked up to it
A clarification on solution #1: Try pressing the tip of the knife (I used the end of a nail file) onto the lower right hand side of the charger area. That's what got it for me. If that doesn't work, try other parts of the end...
Aug 16, 2007 | LG VX5300 Cellular Phone
LG VX5300 Cellular Phone Logo
197 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
