Belkin cooling pad fan stopped working. Is there anything we can do or does it just need to be replaced?
  • 97 Answers
Those are usually throw away items, easier to just replace it.
Posted on Jan 02, 2011
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Hi I got a belkin CoolSpot Anywhere Ultra cooling pad for my laptop but it doesn't work now because the usb is bent. How do I fix this?
Just cut the end off that is bent. Locate a cheap USB extension cord (6 inch is all you need) Cut the 6 inch cord in half and strip the insulation back 1/8 to 1/4 inch. Do the same application with the end attached to the cooling device. With a soldering iron (25 Watt pencil iron) solder the like ends of the exposed wires together. If you have Shrinkable insulation that is a good cover and simple to use. If not use a good insulation tape to cover the soldered wires. That is it!
Mar 13, 2014 | Belkin LAPTOP COOLING PLATFORM * WITH FAN...
Cooling pad grinding noise
As a temp fix, I've noticed that pressing the plastic circular area under the the bottom of the fan may help to realign the fan's bearings.
Basically push up until you hear the fan stop, then slowly release until you hear the fan starts up again. If it still grinds, repeat the process in a slightly different location of the plastic.
It takes a little work, but until a more permanent fix happens it's good enough.
Nov 03, 2013 | Belkin Laptop Cooling Pad
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
My acer gets hot. the fan quit working i think. when it is hot it freezes and you have to turn it off, let it cool then turn it on. you lose the document you are creating. How can i stop it from freezing...
while the computer is off use compress air and spray it into the ventilation area where the fan is that stopped working. hopefully this will free the dust to hopefully get the fan to start moving again.
If the compressed air does not work, you will have to replace the fan.
Mar 05, 2011 | Acer Aspire 4315 Notebook
My logitech cooling station stopped working! The fan for my logitech usb cooling pad N1000 stopped spinning and now my laptop is overheating. Is there anyway to fix this? Do I have to get a new one?
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by
warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some
good deal on nowadays products for out of warranty people.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Jun 15, 2010 | Logitech Notebook Cooling Pad N100 Model...
Belkin cooling fan has stopped working
The problem may be a bent fan blade. It can be hard to see, so look carefully. On my Belkin, something got through the fan grill and bent one blade just enough to stop the fan. By removing the bad blade it continued to run fine.
May 01, 2010 | Belkin LAPTOP COOLING PLATFORM * WITH FAN...
I have a cooling pad and some of the blades have broken off is it possible to buy a new fan piece cooling stand f5l001
LOL it's just a single standard fan in there!  Replace the whole fan with one with similar specs (though of course you can get one with UV LEDs if you want.)  You're welcome to contact Belkin with the question you strangely placed here if you want Factory Original (as if such a thing was still preferred) parts.
Mar 11, 2010 | Belkin LAPTOP COOLING PLATFORM * WITH FAN...
Bought a belkin cooling pad for my laptop on nov 15th. It quit working after a monthto a month and a half. best buy suggested that i call you and you would replace it for me
Belkin cooling pads are very low quality. I know because I owned one, and it shorted out after only a few months of use.
Not sure what you mean about you calling us and us replacing it for you. You could consult the repair directory on the site but it would be wiser to contact Belkin and see if you have a warranty for your product.
The only thing I can tell you is to not buy a Belkin cooling pad again.
Jan 29, 2009 | Computers & Internet
Loud cooling fan hum
If the fan was not that noisy before , this can only be cause by a dirty fan and you may need to clean it up to reduce the hum coming out from it...
Dec 28, 2008 | Acer Extensa Laptop
Computers & Internet Logo
505 people viewed this question
David Payne
David Payne
