Question about Electric Traxxas Stampede Xl-5 Rtr Monster Truck
The led light on the XL-5 ESC blinks green and the truck won't move ?
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Blinking green light
check the motor make sure it move's smoothly. if you hear ticking wile its moving the bushes have warn away. and will need a new motor if it is fine check the wire to the board there is a 3 pin chip half moon shape check this.
Oct 25, 2013 | Electric Traxxas Stampede Xl-5 Rtr ...
I just got a traxxas stampede in dec. i have used it about ten times and now i am having issues when i go to turn it on the green light on the esc comes on and then goes to red and then the light goes off...
make sure ur batteries are fully charged and ur using the right ones for ur model reset ur transmitter to factory default, it sounds like the esc is detecting something wrong when u go to use it bad battery if its a lipo may have ran it to long which can mess them up, I would clean the button on the esc really good, if the truck is making that noise the esc will try to shut down the system if all else fails send in ur esc to traxxas and they will send u a new one for like $50 buck let me know if u get it going
Aug 22, 2017 | Electric Traxxas Stampede Xl-5 Rtr ...
The LED on the XL-5 is solid red after programming. The model operates normally, but the light is supposed to be green. What is wrong?
Press the ez-set button on the esc (the one with the heatsink) for ten seconds until it changes color and gives a beeptone,green is low voltage detection on for use with lipo batteries,if they are fully discharged they are dead,the detection system cuts power beyond 3v per cell so that the lipo isnt dameged
Dec 25, 2010 | Traxxas Rustler Vxl Rtr
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
Dec 05, 2009 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Cartridge seems to move smoothly. Just get the
There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
STEP 1: Clean the printer from inside
  1. Opened the cover and checked the front right of the printer near the waste ink pads
  2. Carefully turn the cogs to move the ink cleaning mechanism
  3. There might be a load of paper jam debris blocking the mechanism from reaching its port
  4. Carefully cleaning this out and putting the printer back together
STEP 2: Reset the error
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
Electric Traxxas Stampede Xl-5 Rtr  Monster Truck Logo
554 people viewed this question
Top Electric Toys Experts
Lawrence Oravetz
Mike Stager
Mike Stager
Are you an Electric Toy Expert? Answer questions, earn points and help others
