Question about Roper REX4634KQ Electric Dryer
Does'nt heat - Roper REX4634KQ Electric Dryer
  • Frank Gilbert
    Frank Gilbert Jan 02, 2011
    Does the dryer drum roll at all?
  • Roper Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
2000 MONTE CARLO BLINKERS DO NT WORK,AC/AND HEAT DO NT WORK,AND RADIO IS SAYING LOCKED UP
Does the vehicle start?
If not, then check battery voltage. If below 12.5 volts, then recharge the battery and retest system charging voltage (should be around 14 volts)
If battery is fine and vehicle starts, then check fuse box and wiring loom connectors.
Nov 13, 2012 | Chevrolet Cars & Trucks
MICRO DOES'NT HEAT
First, check to make sure that the door is closing and latching fully and that there is nothing jamming any of those mechanisms. There are safety devices that keep microwaves from turning on if they think the door is open/ajar.
If the door is fine and the rest of the functions (timer, etc.) are behaving, it's probably a busted magnetron. That's the part that actually emits the waves that do the heating. It's a part that can be replaced, but probably cheaper to get a new microwave.
Oct 02, 2012 | Sharp Microwave Ovens
My minimax nt only heats till 90 degrees. I set it up to 104 which is the highest and it only stays at 90 degrees. Everythig seems to be working well, no errors either. Please advice.
Either the thermostat board is defective, the temperature sensor is defective or not enough heat is being produced by the heater. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Pentair Minimax NT Heater
I have a Pentair MiniMax NT heater about three years old. The unit is making a loud "popping" sound when heating. I think its the heat exchanger from what I am hearing. Can a heat exchanger be cleaned out?...
the heat exchanger can be reamed or replaced but it is quite a job; replacing the heat exchanger is very expensive and time consuming. unless your pool chemicals are extremely out of balance, most especially low ph from using tablet chlorine or too much acid the heat exchanger should not have worn out this quickly. the best solution if you do not have a pool serviceman is to call Leslies Pool Supply or a trained Pentair service tech. It may be worth the service call to have the problem diagnosed by a pro.
Jun 24, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Roper REX4634KQ Electric Dryer Logo
27 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
