Question about Laser Canon imageCLASS 8180C Multifunction Printer
Getting System Error E000 for Canon Image Class MF8170c for All in one Laser.
There are Many MF8180C out there...and they are a good machine...however they had a Manufacturing FAULT and that is the POOR Quality of one Small plug on the FUSER unit RU5-8125....The FEMALE PLUG in the BACK of this machine has faulty Female Pins that Can and DO get pushed back into the base of the PLUG when the fuser is removed and reinserted...
Initally People THINK that the Fuser is BURNT out...BUT
Put a Multimeter across the White leads leadinginto the Fuser and then onto the White lead going INTO the Thermostat on the RHS and you should get a Full Circuit indicating that the heating element is IN FACT still OK ! Then Put the Multimeter on the other end of the plug and TEST the THERMOSTAT with the multimeter in the OHMS setting..you should get a resistance reading....Then the Thermostat is OK also....
NOW Just Look at the PINS in the BACK of the PLUG for the FUSER...most likley one/or two are recessed back in the plug...they should all be even at the FRONT of the PLUG....
Get some tweesers and Pull the little Pins Back out...so they are all lined up....
you will need to keep them there so get a TINY amount of Sicaflex (silicone adhesive-heat resistant...) and Put that UNDER Yes UNDER the Base of the PIN !!! NO UNDER !!!!
if you put in the pin the contacts will not meet....you just need to put a MINUTE amount under this pin to hold it out there.....IF you mess this UP you will have to HARD wire the Fuser in and that is a whole other matter.....
Good Luck Everyone I know this is the issue with the 8180c !!!!
regards Tony Gordon
www.whitelightfilm.com
Posted on Aug 04, 2011
System error e000 canon image class mf4122
Error e000 - error with fixing unit. Try to disassemble printer, remove fixing unit. Check heater element's and thermal sensor's impedance. Check connectors.
May 20, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
System Error E000
This is a fuser error, you can try unplugging the machine and plugging it back in and this might reset the error, however if you try this and the error code pops up again, it could be one of the following which would require having the machine serviced and repaired by a professional. The fuser thermistor could be open or the heater lamp could be open or the thermal fuse that prevents the fuser from overheating could be open.
Sep 03, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Canon ImageClass MF 8180c Error Code E071
i had the same problem, had to replace the drum unit
Mar 10, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Image class
Try this:
Issue: ERROR LCD: System Error E000
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Sep 10, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon Image Class printer
Have you tried this one that Canon has on their website:
Reset the unit
Jun 09, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon d760 system error e000
I used your "Best solution" and it worked
Thank you,Steven
Mar 04, 2008 | Canon imageCLASS D760 All-In-One Laser...
System error E000
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Thanks
Evenel
May 07, 2007 | Canon imageCLASS D860 All-In-One Laser...
Laser Canon imageCLASS 8180C Multifunction Printer Logo
292 people viewed this question
Top Laser Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
CheckitRight
CheckitRight
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
