Hi Take a screw driver and insert it on the door latch to open
the unit to take the clothes out. If this won't help then there is a manual
lock release button located inside the front panel, you can remove the lower
kick panel and then pull the latch down to open the unit. Hope this
helps...please post back for further assistance. Daniel
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
